Some process is continuously eating my free space. Once it dropped to 0 bytes, I freed up some space by deleting few media files, but then it again started to reduce the freed space. I used iotop to findout which process is using disk, and it only shows init and nothing else. Following is a screenshot:
Can anybody help me to fix this.
Thank you.
Deepal
  • 1,676
Use something like htop instead and it will show you the amount of allocated memory for each process.
sudo apt-get update
sudo apt-get install htop
sudo htop
Press F6 to choose what to sort the results by.
Also, have you checked to see if something may be incessantly filling up the error logs?
EDIT:
Because you have identified the culprit is using allotting a lot of space for log-files, you might want to look into using something like logrotate to help manage log-files.
Here is an official description:
Description-en: Log rotation utility
 The logrotate utility is designed to simplify the administration of
 log files on a system which generates a lot of log files.  Logrotate
 allows for the automatic rotation compression, removal and mailing of
 log files.  Logrotate can be set to handle a log file daily, weekly,
 monthly or when the log file gets to a certain size.  Normally, logrotate
 runs as a daily cron job.
Of course, you can also usually change the settings of the application itself to only report errors, to only report warnings and errors, or to fully report everything.
To install logrotate:
sudo apt-get update
sudo apt-get install logrotate
For more info:
man logrotate
mchid
  • 44,904
  • 102
  • 162
