Is it at all possible for me to add a menu entry in this version of GRUB2? All solutions that I have been able to find online involve editing 40_custom, but gedit, vim, etc are all legacy GRUB commands and aren't found.
I looked through the documentation to no avail: http://www.gnu.org/software/grub/manual/grub.html#Command_002dline-and-menu-entry-commands
Problem:
  • my Ubuntu partition isn't showing in the menu options even though I can see the partition it using ls in the grub shell and ls -lh tells me it's a filesystem
  • I would really like to be able to access my Ubuntu again.
Rod Smith
  • 45,120
  • 66
  • 108
There are no menu items for Ubuntu because all copies of the Linux kernel have been deleted from /boot. You can reinstall the kernel as follows:
Boot your computer from an Ubuntu DVD or live-USB, then choose "Try Ubuntu". Once in the Ubuntu session, connect to the internet, open a terminal (Ctrl+Alt+T) and start from step 1 of the instructions at https://askubuntu.com/a/28100/425479.
Note that for step 2 the exact command in your case is:
sudo mount /dev/sda5 /mnt
For step 5, if you have problems with internet only during this step, open a different terminal and type in it:
sudo cp /mnt/etc/hosts /mnt/etc/hosts.old
sudo cp /etc/hosts /mnt/etc/hosts
sudo cp /etc/resolv.conf /mnt/etc/resolv.conf
exit
then try again.
By the start of step 7, Ubuntu will have been added to the Grub menu again, ready for the reboot.
Martin Thornton
  • 5,996
  • 32
  • 43
