I am making a computer testing image for my work. I also want this to run automagically at startup, or at least simply without having to input passwords and start things manually etc. We have a lot of machines we test...
  • I am using Ubuntu 14.04 LTS x64
  • I am using the BurnInTest Linux version as the testing software.
  • At the end I want need to run DD to write a small dos .img file with BIOS updates to the hard drive.
  • I want to run badblocks to test the hard drive.
  • I may need other things to run as root in the future but I could probably figure those out once I figure these out.
I figured booting into single user mode with a GUI would make this easier. I have tried to start a program as root but couldn't figure it out. I also tried changing the grub entry with e and then changing it to single mode but it wouldn't start the gui. When I typed "startx" it showed up a bit but didn't work fully.
I also tried using the OS the Passmark recommends (Slax) I use but it does not boot on the newer machines.
I also know that this is a huge security risk. I understand that. These machines are airgapped on their own network and locked in a room that requires badge access., .
I'm not committed to Ubuntu 14.04 if another version is easier to do this with, I just need a version that will work with my newer machines. (Dell E7250s, Dell E7450s, Lenovo T450s, Lenovo T550s, etc)
Thanks for the input.
Ryan Brown
