My first question: Does Ubuntu support IPSEC/L2TP/PSK vpn CLIENT?
My Second Question: Is there a front end "Network Manager" that supports IPSEC/L2TP and PSK?
Background:
In my endeavors I came across this article: https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/264691 - which i have attempted to use the suggestions in - but am still not able to get a working IPSEC/L2TP/PSK tunnel up as it refrences using openswan.
The Situation:
I was using Werner Jaeger ipsec client and it worked flawlessly - about 3 or 4 months ago it has stopped working. I have attempted to reinstall it on my desktop using Ubuntu Studio 14.04 and Debian 8 and I get the same results.
I now understand that openswan was removed from the distro and superseded by strongswan. I very much would not like to have to move away from linux as one of the things i do is work from home and need vpn to monitor / test / configure networks. Can someone point me to a good tutorial on configuring it as a client?
Side note:
I found this topic L2TP IPsec VPN client on Ubuntu 14.10 - tried all the things in there - still nothing - also that article did not answer the question being that it is for 14.10 and im using 14.04 it is technically different - I have done alot of things thus far to get it to work and nothing has helped. Any help would be much appreciated!!!
Sorry to dump like this here - seriously - i am desperate to get this working and am at my ends with it - it has been like 3 months now since i was able to work on my desktop. All of the research I have done leads me to believe that open swan will not work anymore and I have to use strongswan. (am i wrong?)
so some things i have been trying to do -
Using strongswan I tried doing this:
apt-get install strongswan network-manager-strongswan
It is my understanding that I should see a L2TP/IPSEC option in the network manager. (am i wrong?)
The problem is that l2tp/ipsec/psk as not an option in the network manager after all was installed and rebooted
Also the Werner Jaeger applet disappears after going to strongswan, is that expected?
Next thing I tried to do -
I rolled my machine back to openswan and for the first time in months it gets connected - though after a couple seconds it drops - I figured I'd run 'ipsec verify' to check statuses - below is my steps and my logs minus the sensitive details - any thoughts would be much appreciated
What I ran with to install -
sudo apt-get install openswan
sudo apt-get install xl2tpd
sudo apt-get install l2tp-ipsec-vpn
I then configured the gui applet
I then configured the file:
/etc/ppp/watevs.options.xl2tpd
-Logs-
jason@casa-wesella:~$ sudo ipsec verify
Checking your system to see if IPsec got installed and started correctly:
Version check and ipsec on-path                                 [OK]
Linux Openswan U2.6.38/K3.16.0-43-lowlatency (netkey)
Checking for IPsec support in kernel                            [OK]
 SAref kernel support                                           [N/A]
 NETKEY:  Testing XFRM related proc values                      [FAILED]
  Please disable /proc/sys/net/ipv4/conf/*/send_redirects
  or NETKEY will cause the sending of bogus ICMP redirects!     [FAILED]
  Please disable /proc/sys/net/ipv4/conf/*/accept_redirects
  or NETKEY will accept bogus ICMP redirects!                   [OK]
Checking that pluto is running                                  [OK]
 Pluto listening for IKE on udp 500                             [OK]
 Pluto listening for NAT-T on udp 4500                          [OK]
Two or more interfaces found, checking IP forwarding        Checking NAT and MASQUERADEing                                  [OK]
Checking for 'ip' command                                       [OK]
Checking /bin/sh is not /bin/dash                               [WARNING]
Checking for 'iptables' command                                 [OK]
Opportunistic Encryption Support                                [DISABLED]
> Logs from applet -
Jul 21 15:23:45.505 ipsec_setup: Starting Openswan IPsec U2.6.38/K3.16.0-43-lowlatency...
Jul 21 15:23:46.412 ipsec__plutorun: Starting Pluto subsystem...
Jul 21 15:23:46.659 ipsec__plutorun: adjusting ipsec.d to /etc/ipsec.d
Jul 21 15:23:46.749 recvref[30]: Protocol not available
Jul 21 15:23:46.749 xl2tpd[2313]: This binary does not support kernel L2TP.
Jul 21 15:23:46.749 xl2tpd[2316]: xl2tpd version xl2tpd-1.3.6 started on casa-wesella PID:2316
Jul 21 15:23:46.750 xl2tpd[2316]: Written by Mark Spencer, Copyright (C)
1998, Adtran, Inc.
Jul 21 15:23:46.750 xl2tpd[2316]: Forked by Scott Balmos and David Stipp, (C) 2001
Jul 21 15:23:46.750 xl2tpd[2316]: Inherited by Jeff McAdams, (C) 2002
Jul 21 15:23:46.750 xl2tpd[2316]: Forked again by Xelerance (www.xelerance.com) (C) 2006
Jul 21 15:23:46.751 xl2tpd[2316]: Listening on IP address 0.0.0.0, port 1701
Jul 21 15:23:46.752 Starting xl2tpd: xl2tpd.
Jul 21 15:23:46.891 ipsec__plutorun: 027 bad right --id: does not look numeric and name lookup failed (ignored)
Jul 21 15:23:46.892 ipsec__plutorun: 002 added connection description "Work"
Jul 21 15:23:47.123 104 "Work" #1: STATE_MAIN_I1: initiate
Jul 21 15:23:47.124 003 "Work" #1: received Vendor ID payload [RFC 3947] method set to=115
Jul 21 15:23:47.124 003 "Work" #1: received Vendor ID payload [Dead Peer Detection]
Jul 21 15:23:47.124 003 "Work" #1: ignoring unknown Vendor ID payload [8299031757a36082c6a621de00050282]
Jul 21 15:23:47.124 106 "Work" #1: STATE_MAIN_I2: sent MI2, expecting MR2
Jul 21 15:23:47.124 003 "Work" #1: NAT-Traversal: Result using draft-ietf-ipsec-nat-t-ike (MacOS X): i am NATed
Jul 21 15:23:47.124 108 "Work" #1: STATE_MAIN_I3: sent MI3, expecting MR3
Jul 21 15:23:47.124 004 "Work" #1: STATE_MAIN_I4: ISAKMP SA established {auth=OAKLEY_PRESHARED_KEY cipher=oakley_3des_cbc_192 prf=oakley_sha group=modp1024}
Jul 21 15:23:47.125 117 "Work" #2: STATE_QUICK_I1: initiate
Jul 21 15:23:47.125 003 "Work" #2: ignoring informational payload, type IPSEC_RESPONDER_LIFETIME msgid=8e08921c
Jul 21 15:23:47.125 003 "Work" #2: NAT-Traversal: received 2 NAT-OA. ignored because peer is not NATed
Jul 21 15:23:47.125 004 "Work" #2: STATE_QUICK_I2: sent QI2, IPsec SA established transport mode {ESP=>0x37742a26 <0x478d0d00 xfrm=AES_128-HMAC_SHA1 NATOA=none NATD=none DPD=none}
Jul 21 15:23:48.129 xl2tpd[2316]: Connecting to host Public IP, port 1701
Jul 21 15:23:48.168 xl2tpd[2316]: Connection established to Public IP, 1701.  Local: 57627, Remote: 14608 (ref=0/0).
Jul 21 15:23:48.194 xl2tpd[2316]: Calling on tunnel 57627
Jul 21 15:23:48.212 xl2tpd[2316]: Call established with Public IP, Local: 14783, Remote: 14609, Serial: 1 (ref=0/0)
Jul 21 15:23:48.212 xl2tpd[2316]: start_pppd: I'm running:
Jul 21 15:23:48.213 xl2tpd[2316]: "/usr/sbin/pppd"
Jul 21 15:23:48.213 xl2tpd[2316]: "passive"
Jul 21 15:23:48.213 xl2tpd[2316]: "nodetach"
Jul 21 15:23:48.214 xl2tpd[2316]: ":"
Jul 21 15:23:48.214 xl2tpd[2316]: "file"
Jul 21 15:23:48.214 xl2tpd[2316]: "/etc/ppp/Work.options.xl2tpd"
Jul 21 15:23:48.215 xl2tpd[2316]: "/dev/pts/6"
Jul 21 15:23:48.331 pppd[2427]: Plugin passprompt.so loaded.
Jul 21 15:23:48.332 pppd[2427]: pppd 2.4.5 started by root, uid 0
Jul 21 15:23:48.333 pppd[2427]: Using interface ppp0
Jul 21 15:23:48.333 pppd[2427]: Connect: ppp0 <--> /dev/pts/6
Jul 21 15:23:52.345 pppd[2427]: Remote message: Login ok
Jul 21 15:23:52.346 pppd[2427]: PAP authentication succeeded
Jul 21 15:23:52.390 pppd[2427]: Deflate (15) compression enabled
Jul 21 15:23:52.429 pppd[2427]: local  IP address Private IP
Jul 21 15:23:52.429 pppd[2427]: remote IP address Private IP
Jul 21 15:24:31.977 Stopping xl2tpd: xl2tpd.
Jul 21 15:24:31.977 xl2tpd[2316]: death_handler: Fatal signal 15 received
Jul 21 15:24:31.979 pppd[2427]: Modem hangup
Jul 21 15:24:31.979 pppd[2427]: Connect time 0.7 minutes.
Jul 21 15:24:31.980 pppd[2427]: Sent 10334 bytes, received 13370 bytes.
Jul 21 15:24:31.980 pppd[2427]: Connection terminated.
Jul 21 15:24:31.993 ipsec_setup: Stopping Openswan IPsec...
Jul 21 15:24:32.089 pppd[2427]: Exit.
gingamann
  • 393
