After I rebooted my server, everything started up normally except for "mysql", i tried to start it up manually "/etc/init.d/mysql restart" or with "service mysql restart", it fails
In log file it says:
Jul 16 08:13:38 localhost /etc/init.d/mysql[18136]: error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Jul 16 08:13:38 localhost /etc/init.d/mysql[18136]: Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
I checked that path, but i didn't find that socket file, please advise?
Edit:
root@myserver:/var/log# service mysql restart
 * Stopping MySQL database server mysqld                   [ OK ]
 * Starting MySQL database server mysqld                   [fail]
a simple hack:
sudo ln -s /var/run/mysql/mysql.sock /tmp/mysql.sock
sudo service mysqld restart
If this doesn't work then try this:
First find open socket files for mysql in your system
sudo find / -type s 2>/dev/null | grep mysql
For my case it's /var/lib/mysql/mysql.sock
Then edit the configuration file /etc/my.cnf
sudo gedit /etc/mysql/my.cnf
Then search for socket and edit the entry with the output above
socket=/var/lib/mysql/mysql.sock
Maythux
  • 87,123
I faced with the same issue. And find out that:
  1. My Ubuntu MySQL Config file is in /etc/mysql/mysql.cnf
  2. That file includes all *.cnf file in /etc/mysql/mysql.conf.d and /etc/mysql/conf.d.
  3. the line: log-error = /var/log/mysql/error.log is very useful
Open two shell connection. Run this on first server:
  • tail -f /var/log/mysql/error.log
On second server, just restart mysql:
  • service mysql restart
See the error messages in the error log. In my case, it was these two lines:
  • query_cache_limit = 1M
  • query_cache_size = 16M
I simply comment them, and somehow the mysql can start again.
Try service mysql restart. Ubuntu uses upstart for mysql service (see What's the difference between "Service" and "/etc/init.d/"?), and it's behavior differs from init scripts.
What version of Ubuntu and Mysql are you using? Could you please post above command output and /var/log/mysql*?
gmy
I tried to startup mysql in "Safe Mode" to create the sock file and pid file, but it fails for some error "bind",
  1. I changed the IP address in "bind ip" parameter in my.cnf to localhost
  2. started mysql in safe mode.
  3. restarted mysql in normal mode, and everything went fine.
