I have seen similar threads, but they didn't help me.
I am using Ubuntu 14.04.2 LTS (GNU/Linux 2.6.32-042stab108.5 x86_64) on my VPS.
I ran a node.js application on port 9000, but this port is closed, so I can't see my web page using a web browser via the Internet.
My opened ports:
sudo netstat -ntlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      752/apache2
tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      366/vsftpd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      454/sshd
tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      611/master
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      485/mongod
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      599/mysqld
tcp6       0      0 :::22                   :::*                    LISTEN      454/sshd
tcp6       0      0 :::25                   :::*                    LISTEN      611/master
I was trying to execute the following commands:
sudo iptables -I INPUT -p tcp -m tcp --dport 9000 -j ACCEPT
sudo iptables -A INPUT -p tcp --dport 9000 -j ACCEPT
But it didn't help me. Moreover, the /etc/iptables.rules file is missing, so I couldn't save changes using the following command: iptables-save > /etc/iptables.rules
Could you help me please? Thanks.
Vitone
  • 133
Give this a try
sudo iptables -I INPUT -p tcp -s 0.0.0.0/0 --dport 9000 -j ACCEPT
To make the change permanent
iptables-save > /etc/iptables.conf # Save this changes to file
touch /etc/network/if-up.d/iptables # Create file to call conf from
echo "iptables-restore < /etc/iptables.conf" >> /etc/network/if-up.d/iptables # Add this line to this file
chmod +x /etc/network/if-up.d/iptables  # Make the script executable
Original Source
Rick
  • 267
If you don't see port 9000 with command netstat in listening you app not running or maybe is better to say, your server do not expect connection on that port.
2707974
  • 10,758
