28
I installed VNC, using
sudo apt-get install xfce4 xfce4-goodies tightvncserver
But I can't start it, when I enter
vncserver
I'm getting error message as
Couldn't start Xtightvnc; trying default font path.
Please set correct fontPath in the vncserver script.
Couldn't start Xtightvnc process.
15/07/15 18:59:34 Xvnc version TightVNC-1.3.9 15/07/15 18:59:34 Copyright (C) 2000-2007 TightVNC Group 15/07/15 18:59:34 Copyright (C) 1999 AT&T Laboratories Cambridge 15/07/15 18:59:34 All Rights Reserved. 15/07/15 18:59:34 See http://www.tightvnc.com/ for information on TightVNC 15/07/15 18:59:34 Desktop name 'X' (vultr.guest:1) 15/07/15 18:59:34 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t 15/07/15 18:59:34 Listening for VNC connections on TCP port 5901 Font directory '/usr/share/fonts/X11/misc/' not found - ignoring Font directory '/usr/share/fonts/X11/Type1/' not found - ignoring Font directory '/usr/share/fonts/X11/75dpi/' not found - ignoring Font directory '/usr/share/fonts/X11/100dpi/' not found - ignoring
Fatal server error: could not open default font 'fixed'
I have solved one issue by adding hostname in hosts file. But still having other errors, please help.
user
  • 473
rebornx
  • 709
8 Answers8
32
Atlast after tried many solutions and fixes I fixed this issue. I almost give up, but fixed now.
Problem 1: Couldn't start Xtightvnc process.
Solution: check your hostname, and /etc/hosts make sure both are same. To edit those files, use the commands.
nano /etc/hostname
nano /etc/hosts
hostname
Problem 2:
Solution: The x11 fonts are missing, I don't know why the dependency packages are not installed. Try to find folder
ls /usr/share/fonts/X11/
if it is not found, then try to install xfonts base
apt-get install  xfonts-base
rebornx
  • 709
Maybe to help others - check the logs!
I was running
vncserver -geometty 1200x900 -alwaysshared -localhost -compatiblekbd :1
I experienced the same message
# ... list of tightvnc options
My solution was to check the log
cat ~/.vnc/hostname:display.log | less
which indicated a mispelled option (-geometty) - I missed the message in stdout >_<; it was sandwiched between other things.
On Kubuntu 14.04 I had the same error with tightvnc server, and while debugging switched to vnc4server, which had the same error. I resolved it in vnc4 by setting the font path.
I got the font path by running
xset q
and getting the value of "Font Path:". I then used this as the value for the "-fp" option. E.g.
vncserver -fp "/usr/share/fonts/X11/misc,/usr/share/fonts/X11/Type1,built-ins"
which seems to just pass it through to the underlying Xvnc4 server invocation.
Andy W
  • 61
Some distros lack base font package. Try to download 6x13-ISO8859-1.pcf.gz from https://github.com/BlackArch/blackarch-iso/blob/master/live-iso/airootfs/usr/share/fonts/misc/ and put this file to /usr/share/fonts/X11/misc/.
Sauron
  • 101
Try deleting the old .pid and .log files from ~/.vnc This errors seems to be pretty generic for any I can't read any file for some reason. Messing with fonts probably won't help you.
This worked for me on 16.04 and 18.04 LTS
A.Adverse
  • 305
Fatal server error:
Make sure that in /usr/share/fonts/X11/misc/ there are:
  • fonts.alias file with fixed <fontname> string
  • fonts.dir file with the corresponding <filename> <fontname> string
  • a font file with that filename.
user
  • 473
Since literally none of the above worked for me, the real answer to this problem is to use the following command when using Ubuntu 20.04:
vncserver -rfbport 5901 -fp /usr/share/fonts/X11/misc/,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/75dpi/,/usr/share/fonts/X11/100dpi/ -co /etc/X11/rgb -depth 24 -geometry 1920x1080 -localhost
That means if you set it up as a service, you'll need to edit the ExecStart line as well to include these options.
Sephethus
  • 226
I had the same issue as extra fonts were not installed and I had issue installing extra packages. Solved it by adding DNS servers. I followed this tip.
To add a dns server w/o changing your permanent setup, just add the entries to /etc/resolv.conf. This should reset when you reboot. The below will use the google dns servers. (this only lasts until next reboot)
nameserver 8.8.8.8 nameserver 8.8.4.4
Adding it permanently is a different animal. I would edit /etc/network/interfaces and under the wlan0 block add the following line:
dns-nameservers 8.8.8.8 8.8.4.4
Then do an apt-get update then run any installs like apt-get install xfonts-base
