Hi I'm trying to upgrade an old version of ubuntu server to ubuntu-server-14.04. However there is a large amount of data under /home (1.4 TB) which I do not want to lose. Nor do I prefer to make a hard back up (takes ages + should arrange for resources!). I'm using a bootable USB to install 14.04. I'm not really sure how to proceed at 'Partition disks' stage of the installation to achieve what I need. Attached is the pic of the stage during installation.
Suggestions ?
Edit: Okay, I forgot to add a crucial part of the problem. The old version is a 32-bit version. The 14.04 version I'm trying to install is 64-bit version. 64-bit OS is the primary motivation for the upgrade.
elpuir
  • 13
The ubuntu upgrade process does not effect files in the /home folder. You can run the embedded ubuntu update by the following
To upgrade to a newer release, from a terminal prompt enter:
do-release-upgrade
It is also possible to use do-release-upgrade to upgrade to a development version of Ubuntu. To accomplish this use the -d switch:
do-release-upgrade -d
EDIT Follow my instructions to install Ubuntu 64 bit without losing your current software configuration:
  1. In a terminal execute sudo dpkg --get-selections > ~/softwarelist. Install the x64 Ubuntu over the existing one. If asked to preserve Home, say yes.
  2. Execute sudo dpkg --set-selections < ~/softwarelist.
  3. Execute sudo apt-get -f install. You will have some errors, but all should be fine.
  4. Reboot.
This procedure is valid for the 12.04, it can change with older/newer versions.
Source Upgrading ubuntu 12.04 32 bit to 64 bit
