I'm reinstalling Ubuntu 14.04 for the fifth time today, I already tried several solutions on a completely fresh installation (my default keyboard/mouse don't work during installation, have to use a spare keyboard every time which works, but this is not really a problem).
I managed to get everything running on my old laptop for testing purposes, but now I need the computing power of my desktop machine.
I'm using an nVidia GTX 970 with three screens plugged in: one on HDMI, two on DVI ports with VGA to DVI adapters, one of the VGA to DVI screens is the one that works and it's (conveniently) the oldest/smallest one.
Things I could observe consistently after every single installation:
  • TTY console does not work at all, every single one is just black with no reaction on input but I can still swap back to desktop
  • Only one screen is working (I usually have three in use, but a second would be godsend already) and the others aren't detected in system settings -> displays.
  • Resolution is fine
Some of the things I tried:
sudo apt-get install nvidia-current
sudo nvidia-xconfig
Observed result: UI took longer to initially load and completely froze after I logged in. But it fixed the TTY console issue.
  • Booting directly into text mode to install the driver I downloaded from nvidia website. This are the instructions I used.
Observed result: Boot never finished in text mode (rebooted multiple times) and it somehow crashed, but I couldn't figure out why (I think I can reproduce it if you want me to). This was fixable by booting into recovery mode and reversing the changes to the grub config file.
  • Booting into recovery mode and installing Nvidia drivers from there.
Observed result: Exactly the same as first one.
What do I actually want to accomplish now?
  1. Get my other screens to work so I can work comfortably again.
  2. Get the CUDA Toolkit to work since I want to use it with Torch.ch (can't link it here, only 2 links possible) which is the reason why I gave Ubuntu another try in the first place.
If you need any other information or want me to try something even if you aren't sure about it, please tell me, I already spent hours on it with zero progress, maybe you can do something.
Edit:
Output of nvidia-settings --version as requested:
nvidia-settings:  version 331.20  (buildd@roseapple)  Mon Feb  3 15:07:22 UTC 2014      The NVIDIA X Server Settings tool.
  This program is used to configure the NVIDIA Linux graphics driver.      For more detail, please see the nvidia-settings (1) man page.
  Copyright (C) 2004 - 2010 NVIDIA Corporation.
And what happens after doing
Resolution is much lower after reboot, looks like 800x600 to me.Then the UI crashes (mouse cursor disappears and I sit in front of an empty ubuntu wallpaper) as soon as I enter my user credentials, but the TTY console is working now. So I tried doing
sudo service lightdm restart
which results in 4 times
systemd-udevd[4114]: Failed to apply ACL on /dev/dri/card0: No such file or directory
and taking me back to the same low-res login screen that just crashes on login.
Fabby
  • 35,017
Honestly, I would stick with single monitor for Linux. I tried multi-monitor setup, but it screwed up my screens and I had to reinstall/format/do the whole damn installation again.\
Depending on your graphics card, I would get the drivers from the site, if there are any. I know that some AMD/ATI cards work like plug-and-play.
Don't use converters and if you really must: use externally powered ones that contain a DSP and can do the up/downscaling for you. It's not the modules (a.k.a. "drivers") that's the problem: it's the converters!
The older one is working because it's probably a standard VESA resolution (like 800x600 or 1024x768) and the other one isn't because it doesn't have enough power, or the resolution doesn't work out, or the sync or the ...
If your machine's output is to DVI, use DVI cables connected to DVI-capable monitors. (if you have other ports like HDMI, buy cables for those)
Sorry to be the harbinger of bad news!
Fabby
  • 35,017
