My question is simple :
I have video files named as follows :
  • xxxx_yyy_720_3800.mp4
  • xxxx_yyy_720_8000.mp4
where yyy can vary in length (e.g yyyyyy or more y)
As I'm not used in shell scripts I'd like to delete automatically (in a specified folder)
  • If a file with the name xxx_yyy_720_3800.mp4 exists and if the file xxx_yyy_720_8000.mp4 exists, delete xxx_yyy_720_3800.mp4
  • If there is only a file xxx_yyy_720_8000.mp4 and not a file xxx_yyy_720_3800.mp4, do nothing.
Any help would be greatly appreciated.
Using find and gawk
  1. Install gawk
    sudo apt-get install gawk
  2. Go into your folder or replace the . after the find command with your foldername, eg: find ~/my_video_duplicates f -iname …
  3. Test the command
    The command below shows only the remove candidates
    find . -type f -iname "*_8000.mp4" -print0 | \
        while read -d $'\0' file; do \
            gawk -F_ '{ \
                a=gensub(/\_8000\./, "_3800.", "g" , $0); \
                system("if [ -f \""a"\" ]; then echo \""a"\" will be deleted; fi")}' <<< "$file";\
        done
  4. Check again, if you are in the right folder or replace the . after the find command with your foldername, eg: find ~/my_video_duplicates f -iname …
  5. If you sure, run the command below
            gawk -F_ '{ \
                system("if [ -f \""a"\" ]; then rm \""a"\"; fi")}' <<< "$file";\
        done
Example
  • The starting situation
    % ls -og
    total 3
    -rw-rw-r-- 1 0 Jul 14 19:37 xxxx_yyy_720_3800.mp4
    -rw-rw-r-- 1 0 Jul 14 19:20 xxxx_yyy_720_8000.mp4
    -rw-rw-r-- 1 0 Jul 14 19:21 aaaa_yyy_720_8000.mp4
  • The dry run
    % find . -type f -iname "*_8000.mp4" -print0 | \
            gawk -F_ '{ \
        done
    ./xxxx_yyy_720_3800.mp4 will be deleted
  • The removal
            gawk -F_ '{ \
        done
  • The final situation
    % ls -og
    total 2
A.B.
  • 92,125
Using the Bash Shell
[ -f "file" ] checks whether a filename exists, and is an ordinary file (e.g. not a directory or symbolic link)
"${name/%x/y}" replaces the suffix x of $name with y.
Therefore to delete xxx_yyy_720_3800.mp4 only if xxx_yyy_720_8000.mp4 exists, where xxx and yyy are identical in each case, for all *_*_720_3800.mp4 in the current directory:
for name in *_*_720_3800.mp4
do if [ -f "${name/%3800.mp4/8000.mp4}" ]
   then echo "$name"
   fi
done
Change the echo to rm if you are sure this is OK.
Martin Thornton
  • 5,996
  • 32
  • 43
