We recently purchased a Canon printer for our home. My wife's works fine because she uses a Mac.
I cannot find the drivers for the Canon MG7520 printer series printer. How does one install that particular printer so i can print it?
P.s. This is for my ubuntu 14.04 computer.
Canon printers all seem to share the same debian driver. I test this with the Canon MG7520 printer on Ubuntu 14.04.
Printer Installation Steps
Download the debian driver found here on Canon's Website:
http://support-asia.canon-asia.com/contents/ASIA/EN/0100626502.html
Extract the tar.gz file and then run the install.sh file:
tar -xvf cnijfilter2-5.00-1-deb.tar.gz
cd cnijfilter2-5.00-1-deb
./install.sh
Installing the scanner
The scanner can be found here: http://support-ph.canon-asia.com/contents/PH/EN/0100627102.html
Repeat the same steps:
  • Download the tar file
  • Extract
  • run ./install.sh file
After installing the scanner run:
scangearmp2 to start the scanner software. It'll scan for your scanner.
Sources:
If you want ScangearMP to appear in the Dash, you can create a .desktop file for it.
Copy the following into a text editor:
[Desktop Entry]
Version=1.0
Name=ScanGear2 MP
Comment=Cannon's scanner software
Exec=/usr/bin/scangearmp2
Icon=/usr/share/icons/gnome/256x256/devices/scanner.png
Terminal=false
Type=Application
Categories=Utility;Application;Graphics;Scanning;
Save the file with filename scangearmp.desktop
To use the desktop file from the Dash you will need to copy it to /usr/share/applications for any user to be able to use it (you will need administrator permissions) or to ~/.local/share/applications (where ~ means your user directory) if you just want it to be available for one user.
Source: adapted from Canon (MG 5350) scangear doesn't appear in dash
