I have to give someone access to my computer, but I want to know afterwards which files he accessed... Can I create a log file for that? Is there an existing program for that? I know how to track processes but I just want the files accessed by one user.
Using iwatch
iwatch o_O is a realtime filesystem monitoring program using inotify
and a working local mail service
For a better obscurity you should change the mail address and start the deamon as root, or something else … :)
sudo apt-get install iwatch
Create a configuration file with the name
iwatch.xml<?xml version="1.0" ?> <!DOCTYPE config SYSTEM "/etc/iwatch/iwatch.dtd" > <config> <guard email="username@localhost" name="iWatch"/> <watchlist> <title>a title</title> <contactpoint email="username@localhost" name="foo bar"/> <path type="recursive" events="default">/home/username</path> </watchlist> </config>Start the deamon
iwatch -d -f iwatch.xml -p ~/iwatch.pid-dExecute the application as daemon. iWatch will run in foregroud without this option.-fSpecify alternative configuration file. Default is/etc/iwatch/iwatch.xml-pSpecify an alternate pid file. Default:/var/run/iwatch.pidCheck your local mails ;)
Some interesting events
-e event [,event[,..]]
Specify a list of events you want to watch. Following are the possible events you
can use:
access : file was modified
modify : file was modified
attrib : file attributes changed
close_write : file closed, after being opened in writeable mode
close_nowrite : file closed, after being opened in read-only mode
close : file closed, regardless of read/write mode
open : file was opened
moved_from : File was moved away from.
moved_to : File was moved to.
move : a file/dir within watched directory was moved
create : a file was created within watched director
delete : a file was deleted within watched directory
delete_self : the watched file was deleted
unmount : file system on which watched file exists was unmounted
q_overflow : Event queued overflowed
ignored : File was ignored
isdir : event occurred against dir
oneshot : only send event once
all_events : All events
default : close_write, create, delete, move, delete_self and move_self.
More information here
- 92,125
Don't reinvent the wheel - badly.
Use auditing. Tracking who accesses what files is exactly what auditing is for.
A good link to get started is here.
Auditing goals
By using a powerful audit framework, the system can track many event types to monitor and audit the system. Examples include:
- Audit file access and modification
- See who changed a particular file
- Detect unauthorized changes
- Monitoring of system calls and functions
- Detect anomalies like crashing processes
- Set tripwires for intrusion detection purposes
- Record commands used by individual users
- 165
Using find
The following solution works not with deleted files and, if you have not set noatime in your fstab, eg:
defaults,noatime
Using find after you have your account back.
find ~ -atime -1
means, accessed less than 1 day.
Or a combination:
find ~ -atime 1 -atime -2
means 1-2 days ago
from man find
-atime n
File was last accessed n*24 hours ago. When find figures
out how many 24-hour periods ago the file was last accessed,
any fractional part is ignored, so to match -atime +1, a file
has to have been accessed at least two days ago.
-amin n
File was last accessed n minutes ago.
- 92,125
