The Dwarf Fortress archive you downloaded features no dependency resolution, and that error indicates you haven't installed the necessary libraries to play.
Open a terminal and enter the following:
sudo apt-get install libsdl1.2debian libsdl-image1.2 libsdl-ttf2.0-0
That should allow Dwarf Fortress to run correctly unless you are on a 64-bit installation. On 64-bit installations, you may need to add ":i386" as seen here:
sudo apt-get install libsdl-image1.2:i386 libsdl-ttf2.0-0:i386 libgtk2.0-0:i386 libjpeg62:i386 libglu1-mesa:i386 libopenal1:i386
You may also run into problems with sound. If so, you can follow the directions on the dwarf fortress wiki, which suggest the following:
$ cd df_linux/libs
$ ln -s /usr/lib/i386-linux-gnu/libopenal.so.1 ./libopenal.so
$ ln -s /usr/lib/i386-linux-gnu/libsndfile.so.1 ./libsndfile.so
