I am importing photos in Shotwell folder by folder, adding tags and titles. All was going well but suddenly after selecting a folder using import in file, there is a box asking if I want to cancel, copy photos or import in place.
I choose import and then get another box saying:
1 non-image file skipped
and then there is no copying and I need to go to file again and redo the process, now it will copy and import.
How can I get rid of this bug? I tried restarting but that doesn't work.
Zanna
  • 72,312
Ton Baars
  • 61
I had the same problem.
Shotwell used to compare md5; see How does Shotwell detect duplicates?.
I could not find how to set variable NO_DUPE_DETECTION. The only solution for me was to change the md5 PhotoTable field of the table using
sqlite3 ~/.local/share/shotwell/data/photo.db  "update phototable set md5=''"
You can add a function to .bashrc
rmmd5 ()
and run it every time you import.
Zanna
  • 72,312
Andres
