In Trusty udisks2 is installed by default and used by nautilus.
The binary is in
/usr/bin/udisksctl
found via dpkg -L udisks2 | grep bin/
from man udisksctl
NAME
udisksctl - The udisks command line tool
SYNOPSIS
udisksctl status
udisksctl info {--object-path OBJECT | --block-device DEVICE}
udisksctl mount {--object-path OBJECT | --block-device DEVICE} [--filesystem-type TYPE] [--options OPTIONS...] [--no-user-interaction]
udisksctl unmount {--object-path OBJECT | --block-device DEVICE} [--force] [--no-user-interaction]
udisksctl unlock {--object-path OBJECT | --block-device DEVICE} [--no-user-interaction]
udisksctl lock {--object-path OBJECT | --block-device DEVICE} [--no-user-interaction]
udisksctl loop-setup --file PATH [--read-only] [--offset OFFSET] [--size SIZE] [--no-user-interaction]
udisksctl loop-delete {--object-path OBJECT | --block-device DEVICE} [--no-user-interaction]
udisksctl power-off {--object-path OBJECT | --block-device DEVICE} [--no-user-interaction]
udisksctl smart-simulate --file PATH {--object-path OBJECT | --block-device DEVICE} [--no-user-interaction]
udisksctl monitor
udisksctl dump
udisksctl help
Here is a short test
% sudo apt-get remove udisks2
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
arronax arronax-nautilus brasero deja-dup-backend-gvfs gnome-disk-utility
gnome-shell-extensions gnome-sushi gvfs gvfs-backends gvfs-backends-goa
gvfs-daemons gvfs-fuse nautilus nautilus-sendto nautilus-share software-center
ubuntu-gnome-desktop udisks2 usb-creator-common usb-creator-gtk
0 upgraded, 0 newly installed, 20 to remove and 0 not upgraded.
After this operation, 20,9 MB disk space will be freed.
Do you want to continue? [Y/n]
udisks
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 1.043 kB disk space will be freed.
