I've recently installed Linux on my Chromebook, and it’s turning out to be a complete nightmare. It’s a Chromebook C720.
My first problem is that Ubuntu will not boot. Whenever I enter the user name and password, I receive the following error:
/usr/lib/update-notifier/update-motd-fsck-at-reboot: 33: /usr/lib
/update=notifier/update-motd-fsck-at-reboot: cannot create /var/lib/update-notifier/fsck
-at reboot: Read-only file system.
Furthermore, something is wrong with my administrator profile. Every intervention I attempt in order to fix this problem is futile, as it seems my administrator privileges are non-existent. Whenever I use the sudo command in conjunction with some other request, I receive this error:
sudo: unable to open /var/lib/sudo/user/tty1: No such file or directory.
Another example of this administrator issue is my being denied access to certain files. For example, when I type /etc/fstab, I get this lovely response:
-bash: /etc/fstab: Permission denied
As you can see, it's one problem after another with this device. Before I consider reinstallation, I wanted to try and fix it at least. Can anyone provide me with a straightforward method of handling these issues?
Finally, I am aware that I can use the “edit” function on bootloader and change ro to rw on the Linux line. (I can also boot up in start up.) I would rather not have to use these roundabout techniques to boot up my laptop, though.
