How do I install Silverlight plugin in Ubuntu? And how to configure browser with Silverlight plugin?
You cannot install Silverlight in Ubuntu since it is a proprietary Microsoft plugin that does not work with Linux. If you need silverlight functionality you can try your luck with Pipelight which is an open source implementation of this.
You can install pipelight directly from their ppa:
sudo add-apt-repository ppa:pipelight/stable sudo apt-get update sudo apt-get install --install-recommends pipelight-multi sudo pipelight-plugin --update
- 833
Here's how you can install it.
Open a terminal window. Type in the following commands then hit Enter after each:
sudo apt-get update
sudo apt-get install pipelight
sudo pipelight-plugin --enable silverlight
silverlight is not available for Ubuntu.
but you can use the free implementation of it:
pipelight or moonlight
sudo apt-get install moonlight-plugin-core moonlight-plugin-mozilla
or
sudo apt-get update
edit: just discovered that moonlight seems no more under active development [http://www.mono-project.com/docs/web/moonlight/]
- 85
- 8
From mono-project.com:
Moonlight isn’t actively developed anymore. If you’re feeling adventurous you can probably get it working by compiling from source, but we recommend you move away from Moonlight as soon as possible.
