After installing a recent update (Can't tell you any details since I can't access anything), I can no longer log in on Ubuntu 14.04. I just get booted back to the login screen after a second or two whenever I try, and it plays an error sound but displays no other new information. Same thing happens if I try to start a guest session, but if I enter the wrong password it shows a password error as usual. The login screen also runs in a very low resolution (Probably 800x600 or something), but I have no extra screens or anything else to cause problems. On my Windows partition on the same drive, everything functions normally.
EDIT: This thread describes a similar issue, (without the low resolution), but I tried the commands suggested in the top post, and I don't have any of those problems. I've tried reconfiguring lightdm, replacing it with gdm, and tried deleting /Xauthority, but nothing makes any difference.
Some of the answers in the other thread vaguely suggested that it might be a graphics issue, which seems likely given that my resolution is wrong. However, they didn't provide any solution, so I'm still stuck with that.
For anyone else who has this issue (low resolution and login loop after update on Ubuntu 14.04) I've just encountered it on my machine... It has a nvidia graphics card too (GTX 750ti) which seems to be the source of the problem. I booted in safe graphics mode and selected the option "drop to root shell prompt". From here I logged in and then reinstalled the nvidia driver, which for me was conveniently still in Downloads.
sudo nvidia-xconfig
cd ~/Downloads
sudo sh NVIDIA-Linux-x86_64-352.55.run
I followed the install prompts (saying continue/OK to everything!) and then rebooted. Now everything is back to normal again :)
I've not tested this, but if you don't have the appropriate nvidia driver you could find it on the nvidia website: http://www.nvidia.com/Download/index.aspx?lang=en-us
And then retive it using wget:
wget "http://uk.download.nvidia.com/XFree86/Linux-x86_64/352.55/NVIDIA-Linux-x86_64-352.55.run"
hg8
  • 13,582
JonG
  • 16
