I have Infinality patches installed, however fonts look not so good. Using subpixel layout detection page at lagom.nl I discovered that my monitor has BGR layout, but Infinality uses default RGB.
How can I configure Infinality to use BGR subpixel font rendering?
kolen
  • 453
You need to change setting called rgba from rgb to bgr.
<fontconfig>
  <match target="font">
    <edit name="rgba" mode="assign">
      <const>bgr</const> <!-- here -->
    </edit>
  </match>
</fontconfig>
I'm on Arch, and for me it was in /usr/share/fontconfig/conf.avail.infinality/10-base-rendering.conf. On your system it might be different, just grep for rgba in all *.conf files. A reboot/X restart might also be required.
EDIT I just realized that a package upgrade might revert this back to the default. So the right location for this is etc/fonts/local.conf, you can create it if it doesn't exist.
Boris B.
  • 304
