37
I'm just starting out in Ubuntu/Linux, and have some trouble opening port 80 for incoming connections.
I ran the sudo ufw allow 80/tcp command, and when I run sudo ufw status the result looks like this:
Status: active
To                         Action      From
22                         ALLOW       Anywhere
80/tcp                     ALLOW       Anywhere
22 (v6)                    ALLOW       Anywhere (v6)
80/tcp (v6)                ALLOW       Anywhere (v6)
However, I still get this error when trying to connect to the port with cURL.
Failed to connect to MY_IP_ADDRESS port 80: Connection refused
When I run this command netstat -ntlp | grep LISTEN to see what ports are open, I get this result:
(No info could be read for "-p": geteuid()=1000 but you should be root.)
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
Which doesn't look that promising..
How do I open port 80 for incoming connections?
martin
  • 481
6 Answers6
23
There is no program listening on port 80 so it's closed and you can't connect to it.
You can use
sudo python -m SimpleHTTPServer 80
For Python-3:
sudo python3 -m http.server 80
to start a simple web server listening on port 80, or install something like Apache (package apache2) if you want a full blown web server.
Error404
  • 8,278
  • 35
  • 60
18
UFW is the Uncomplicated Firewall. It manages what ports on your computer can be opened for listening by an application. sudo ufw allow 80/tcp means allow TCP connections to port 80.
However, there is nothing actually listening in behind the port. To curl the port, there should be an application that will send a reply. This is typically called a server. As @Florian points out, you can use Python's SimpleHTTPServer to test it.
meshy
  • 124
xyz
  • 1,836
12
Use:
sudo iptables -A INPUT -p tcp --dport 80 -j ACCEPT
Then to prevent it from losing the iptables configuration on restart, use:
sudo apt-get install iptables-persistent
well what worked for me was to use iptable
azerafati
  • 1,189
you can use sudo iptables -A INPUT -p tcp --dport 80 -j ACCEPT this accepts the port when it configures with the port to prevent from losing this terminal line of code you can use sudo apt-get install iptables-persistent The reason for sudo in the beggining of a command is to let it run as superuser the persistant uses it as a persistant connection to the port that is supplied. You can also use you can use Python's SimpleHTTPServer to test it! This was a great question! Thank You!
Galien1
  • 67
This works for me Just Allow the 80 from iptables
Akitha_MJ
  • 301
