I've been trying to install a package from a PPA for some hours now. I am running a freshly installed version of ubuntu 14.04.
I've been following these instructions: https://github.com/ethereum/go-ethereum/wiki/Installation-Instructions-for-Ubuntu
On issuing this command:
sudo add-apt-repository ppa:ethereum/ethereum
I get five errors of this kind: (all of them added to the bottom of the post for reference.)
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 119, in <module>
shortcut = shortcut_handler(line)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 837, in shortcut_handler
ret = factory(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 382, in shortcut_handler
return PPAShortcutHandler(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 346, in __init__
info = get_ppa_info(self.shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 333, in get_ppa_info
_get_suggested_ppa_message(user, ppa))
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 292, in _get_suggested_ppa_message
lp_user = get_info_from_lp(LAUNCHPAD_USER_API % user)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 87, in get_info_from_lp
return _get_https_content_py3(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 107, in _get_https_content_py3
raise PPAException("Error reading %s: %s" % (lp_url, reason), e)
softwareproperties.ppa.PPAException: 'Error reading https://launchpad.net/api/1.0/~ethereum: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)'
I would think that this has something to do with this line:
I've tried reinstalling and updating the ca-certificates. And I have run apt-get update and upgrade. (I also tried 15.04 but same results)
Do I have to add/generate a certificate for this particular host?
Any ideas what I might be missing here?
Thankful for any help!
FULL ERROR MESSAGES:
File "/usr/lib/python3.4/urllib/request.py", line 1182, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.4/http/client.py", line 1088, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1126, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1084, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 922, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 857, in send
self.connect()
File "/usr/lib/python3.4/http/client.py", line 1231, in connect
server_hostname=server_hostname)
File "/usr/lib/python3.4/ssl.py", line 365, in wrap_socket
_context=self)
File "/usr/lib/python3.4/ssl.py", line 583, in __init__
self.do_handshake()
File "/usr/lib/python3.4/ssl.py", line 810, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 101, in _get_https_content_py3
lp_page = urllib.request.urlopen(request, cafile=LAUNCHPAD_PPA_CERT)
File "/usr/lib/python3.4/urllib/request.py", line 161, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.4/urllib/request.py", line 463, in open
response = self._open(req, data)
File "/usr/lib/python3.4/urllib/request.py", line 481, in _open
'_open', req)
File "/usr/lib/python3.4/urllib/request.py", line 441, in _call_chain
result = func(*args)
File "/usr/lib/python3.4/urllib/request.py", line 1225, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/lib/python3.4/urllib/request.py", line 1184, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)>
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 321, in get_ppa_info
ret = get_ppa_info_from_lp(user, ppa)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 91, in get_ppa_info_from_lp
return get_info_from_lp(lp_url)
softwareproperties.ppa.PPAException: 'Error reading https://launchpad.net/api/1.0/~ethereum/+archive/ubuntu/ethereum: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)'
self.send(msg)
self.connect()
_context=self)
self.do_handshake()
'_open', req)
raise URLError(err)
