vmiaffossa@phd-vmiaffossa:~$ sudo apt-get install  openjdk-8-jre-headless
sudo: unable to resolve host phd-vmiaffossa
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  ca-certificates-java java-common
Suggested packages:
  default-jre equivs openjdk-8-jre-jamvm fonts-dejavu-extra fonts-ipafont-gothic
  fonts-ipafont-mincho ttf-wqy-microhei ttf-wqy-zenhei fonts-indic
The following NEW packages will be installed:
  ca-certificates-java java-common openjdk-8-jre-headless
0 upgraded, 3 newly installed, 0 to remove and 113 not upgraded.
3 not fully installed or removed.
Need to get 0 B/63,2 MB of archives.
After this operation, 276 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up udev (219-7ubuntu6) ...
Job for systemd-udevd.service failed. See "systemctl status systemd-udevd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript udev, action "restart" failed.
dpkg: error processing package udev (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of systemd:
 systemd depends on udev; however:
  Package udev is not configured yet.
dpkg: error processing package systemd (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
please, can someone suggest something to solve it ?
visquis
It seems udev is not installed all the way or has an error in the package.
Using sudo dpkg --configure -a should attempt to fix the problem.
If that should not work, find the udev package in /var/cache/apt/archives/udev... and use that .deb in dpkg -i --force-all /var/cache/apt/archives/udev... that will for the install of udev and should solve the problem you are having.
excerpt of the Questions log file
Setting up udev (219-7ubuntu6) ... Job for systemd-udevd.service failed. See "systemctl status systemd-udevd.service" and "journalctl -xe" for details. invoke-rc.d: initscript udev, action "restart" failed. dpkg: error processing package udev (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of systemd: systemd depends on udev; however: Package udev is not configured yet.
