I've been trying for a few days to get this to work but I can't get both Ubuntu 14.04.2 to dual boot with Windows 8.1. These are the steps I followed:
  1. Install Windows and during installation I convert the harddrive to GPT
  2. try to install Ubuntu and it still doesn't say install next to Windows and doesn't show any of my partitions.
I made 3 partitions, one for Windows, one for Ubuntu and another for games and such. I tried booting in UEFI and BIOS mode and none of it works.
This is my first time using Ubuntu so I'm not familiar with all of the workings but I read somewhere that I needed my harddrive in GPT format so that's what I did.
Specs:
  • Fx8320
  • Asus m5a99fx pro r2.0
  • 8gb gskill 1866mhz ram
  • 2tb wd green
  • Thermaltake 650w psu
  • Hd Radeon 7790
  • Gtx 750ti (took it out during Ubuntu install due to it not working without drivers) yes I run them together due to one controlling another monitor.
The output of sudo gparted --list is:
Warning: /dev/sda contains GPT signatures, indicating that it has a GPT table.
However, it does not have a valid fake msdos partition table, as it should.
Perhaps it was corrupted -- possibly by a program that doesn't understand GPT partition tables.
Or perhaps you deleted the GPT table, and are now using an msdos partition table.
Is this a GPT partition table?
Yes/No?
How should I proceed?
Fabby
  • 35,017
In my general experience (I've recently moved to Ubuntu as my sole OS), it shouldn't matter too much about formatting the hard drive before installing Ubuntu. You can create your partition as part of the installation process. So, my advice would be: Install Windows first, then install Ubuntu and create the partition as part of the install.
Just press Y on the sudo gparted --list question and install again...
That will solve your problem …
A.B.
  • 92,125
Fabby
  • 35,017
