45
I am using Ubuntu 14.04.2. I want to install the latest version of Octave (Octave 4.0.0 ). But in official Ubuntu repository ,there is only octave version 3.8 available for download/install.
How can I install Octave 4.0.0 safely/easily in Ubuntu 14.04.2?
I don't want to install/compile it directly from source which is available at official website, because I feel it is not easy method to install.
muru
  • 207,228
Yuvaraj V
  • 1,806
6 Answers6
75
You have two options:
  1. Use the octave ppa, which already has the 4.0 version. You can install octave like this:
    sudo add-apt-repository ppa:octave/stable
    sudo apt-get update
    sudo apt-get install octave
  2. Download and compile the sources yourself:
    sudo apt-get build-dep octave
    wget ftp://ftp.gnu.org/gnu/octave/octave-4.0.0.tar.gz
    tar xf octave-4.0.0.tar.gz
    cd octave-4.0.0/
    ./configure
    make
    sudo make install
mdd
  • 1,441
  • 14
  • 17
You can try this, just type the following commands in terminal and compile the source easily:
sudo apt-get install gcc g++ gfortran make libblas-dev liblapack-dev libpcre3-dev libarpack2-dev libcurl4-gnutls-dev epstool libfftw3-dev transfig libfltk1.3-dev libfontconfig1-dev libfreetype6-dev libgl2ps-dev libglpk-dev libreadline-dev gnuplot libgraphicsmagick++1-dev libhdf5-serial-dev openjdk-7-jdk libsndfile1-dev llvm-dev lpr texinfo libglu1-mesa-dev pstoedit libjack0 libjack-dev portaudio19-dev libqhull-dev libqrupdate-dev libqscintilla2-dev libqt4-dev libqtcore4 libqtwebkit4 libqt4-network libqtgui4 libsuitesparse-dev zlib1g-dev libxft-dev autoconf automake bison flex gperf gzip librsvg2-bin icoutils libtool perl rsync tar libosmesa6-dev libqt4-opengl-dev
rm octave-4.0.0.tar.gz
cd octave-4.0.0/
./configure
make -j4
sudo make install
This was OK for Ubuntu & Mint (you can use the command "make" without arguments if you are using a old computer).
Bendermh
  • 79
This worked for me at the end.
In terminal, install
In synaptic, install
libqt4-opengl-dev
Then, download octave-4.0.0.tar.gz from ftp://ftp.gnu.org/gnu/octave/
unzip octave-4.0.0.tar.gz to home.
cd octave-4.0.0
./configure
make
sudo make install
This worked on all the machines I tried in my laboratory.
Use this link:
Five simple instructions to compile Octave 4.0.0 on Ubuntu
  1. get necessary dev-tools
    sudo apt-get install g++ gcc gfortran make autoconf automake bison flex gperf gzip icoutils librsvg2-bin libtool perl rsync tar
  2. get necessary packages
    sudo apt-get install libblas-dev liblapack-dev libpcre3-dev libarpack2-dev libcurl4-gnutls-dev epstool libfftw3-dev transfig libfltk1.3-dev libfontconfig1-dev libfreetype6-dev libgl2ps-dev libglpk-dev libreadline-dev gnuplot libgraphicsmagick++-dev libhdf5-serial-dev openjdk-7-jdk libsndfile1-dev llvm-dev lpr texinfo libgl1-mesa-dev libosmesa6-dev pstoedit portaudio19-dev libqhull-dev libqrupdate-dev libqscintilla2-dev libqt4-dev libqtcore4 libqtwebkit4 libqt4-network libqtgui4 libsuitesparse-dev libxft-dev zlib1g-dev
  3. download and extract
    cd /tmp
    wget -c ftp://ftp.gnu.org/gnu/octave/octave-4.0.0.tar.gz
    tar -xzf octave-4.0.0.tar.gz
    cd octave-4.0.0
  4. configure and make
    ./configure --prefix=/opt/octave-4.0.0 CPPFLAGS=-I/usr/include/hdf5/serial LDFLAGS=-L/usr/lib/$(dpkg-architecture -qDEB_HOST_MULTIARCH)/hdf5/serial
    make
    make check
  5. install
    sudo make install
muru
  • 207,228
I think you need fort77 compiler... try this:
sudo apt-get install g++ gcc fort77
wget ftp://ftp.gnu.org/gnu/octave/octave-4.0.0.tar.xz
tar Jxvf octave-4.0.0.tar.xz
cd octave-4.0.0
./configure
make
sudo make install
David Foerster
  • 36,890
  • 56
  • 97
  • 151
You have two popular methods to install the latest octave. One is fast while other is slow. Installing from the binaries is fast. While installing from the source is rather complex and lengthy. Here both are here.
From Source
Open command terminal using this key CTRL+ALT+T
Type these commands
tar xzvf octave-4.0.0.tar.gz
cd octave-4.0.0
.configure
make
make install
Default installation location of octave is /usr/local/lib/octave
Default command location is /usr/local/bin/octave
you can see the help using this command
./configure --help
There is already file for installation instruction octave.installation in the source directory.
From Binaries using repository.
use these command to install the octave from binaries. It is fast and easy.
If you don't have java JDK and want to install the java JDK7. Then, use this command.
if you have java and don't want to install the java then use this command to install the necessary tools.
sudo apt-get install gcc g++ gfortran make libblas-dev liblapack-dev libpcre3-dev libarpack2-dev libcurl4-gnutls-dev epstool libfftw3-dev transfig libfltk1.3-dev libfontconfig1-dev libfreetype6-dev libgl2ps-dev libglpk-dev libreadline-dev gnuplot libgraphicsmagick++1-dev libhdf5-serial-dev libsndfile1-dev llvm-dev lpr texinfo libglu1-mesa-dev pstoedit libjack0 libjack-dev portaudio19-dev libqhull-dev libqrupdate-dev libqscintilla2-dev libqt4-dev libqtcore4 libqtwebkit4 libqt4-network libqtgui4 libsuitesparse-dev zlib1g-dev libxft-dev autoconf automake bison flex gperf gzip librsvg2-bin icoutils libtool perl rsync tar libosmesa6-dev libqt4-opengl-dev
Add the PPA using this command.
sudo apt-add-repository ppa:octave/stable
Update the local repository
sudo apt-get update
You can see the octave packges in the local repository
sudo apt-cache search "octave"
You will see the list which containing the octave. Install the latest the GNU octave using this command.
Note You can also use the aptitude instead of apt-get. Aptitude command is more intelligent than the apt-get
Elder Geek
  • 36,752
