11
How can I see my IP address on Ubuntu? I used
ifconfig eth0
but it only displays HWaddr and I don't see where the IP address is.
A.B.
  • 92,125
Hdavu Wind
  • 131
8 Answers8
The following command will output all of your current IP addresses, separated by spaces:
hostname -I
Kaz Wolfe
  • 34,680
tomd
  • 191
Your best to use ifconfig without the interface as it may not be eth0.
ifconfig | less
will allow you to page down to see what interface is assigned an IP.
You can also cheat by using route to see what interfaces are being used.
$ route
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         192.168.138.1   0.0.0.0         UG    0      0        0 eth2
and then use ifconfig on the interfaces listed, eg.
ifconfig eth2
Codeguy007
  • 225
Use command: ip addr show and look for your interface, for example wlan0 for WiFi and eth0 for network card.
Mike
  • 5,931
If ifconfig doesn't show an IP the interface doesn't have one assigned. Assign one with sudo ifconfig 1.2.3.4 netmask 255.255.255.0 or use dhclient -d [iface] if you have a DHCP server in your network (if your uncertain try it, it doesn't hurt and is easier if it works).
If you're connected to the network through a wireless NIC, ifconfig eth0 is useless, because it will show the output of ifconfig for the first ethernet NIC (if any):
ifconfig wlan0
Or wlan1, wlan2, wlan3, [...] depending on how the NIC in use has been mapped (in case you have multiple wireless NICs).
To display only the IP address:
ifconfig wlan0 | sed -n '2s/[^:]*:\([^ ]*\).*/\1/p'
kos
  • 41,268
Personally I use nmcli dev show (15.04) or nmcli dev list (14.04 and earlier). It lists full information about your interfaces, dns, nearest access points, and of course your IPv4 address. You can use awk to trim the info as desired.
A.B.
  • 92,125
After typing
ifconfig eth0
your IP should be listed under
inet addr
Something like:
inet addr:10.0.2.15 Bcast: 10.0.2.255 Mask:255.255.255.0
In this example, 10.0.2.15 would be your IP address.
A.B.
  • 92,125
rye
  • 109
Show all your IPv4 addresses:
LANG=C ifconfig | awk -F: '/inet addr/ {gsub(/ .*/,"",$2); print $2}'
Or for IPv6:
LANG=C ifconfig | awk '/inet6 addr/ {print $3}'
Or an other version:
ip addr show | awk '/inet/ {print $2}'
If you only see something like this:
127.0.0.1/8
::1/128
than you have no IP address. (127.0.0.1 doesn't count as this is your system aka localhost.)
Sample output
% LANG=C ifconfig | awk -F: '/inet addr/ {gsub(/ .*/,"",$2); print $2}'
192.168.2.131
127.0.0.1
% LANG=C ifconfig | awk '/inet6 addr/ {print $3}'
fe80::92e2:baff:fe21:c902/64
::1/128
% ip addr show | awk '/inet/ {print $2}'
127.0.0.1/8
::1/128
192.168.2.131/24
Fabby
  • 35,017
A.B.
  • 92,125
