When i try to install mysql by this command on ubuntu 14.04 i get this error. Help me with simple and detailed solution as I am new on ubuntu.
sudo apt-get install mysql-server
Error:
Reading package lists... Done
Building dependency tree
 mysql-server : Depends: mysql-community-server (= 5.6.25-3ubuntu15.04) but it is not going to be installed
kos
  • 41,268
user4724926
  • 111
You can try a clean uninstall of all that is related to mysql.
sudo apt-get purge mysql-community-server mysql-server
And then reinstall the mysql-server. If that does not work, try to do a search for mysql using apt:
apt-cache search mysql
And try to install another version for mysql-server and mysql-client.
