I am unable to download videos from Youtube using youtube-dl. Below is the code. Please help!
root@itzamlan10:~# sudo apt-get install youtube-dl
Reading package lists... Done
Building dependency tree
youtube-dl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 82 not upgraded.
root@itzamlan10:~#
root@itzamlan10:~# youtube-dl https://www.youtube.com/watch?v=2wNvUHBVw5U
[youtube] 2wNvUHBVw5U: Downloading webpage
ERROR: Unable to download webpage: HTTP Error 429: Too Many Requests (caused by HTTPError()); please report this issue on https://yt-dl.org/bug .
Make sure you are using the latest version; type  youtube-dl -U  to update. Be sure to call youtube-dl with the --verbose flag and include its com
plete output.
Your problem is almost certainly because you're running an older version of youtube-dl.
You should uninstall the apt version with
apt-get purge youtube-dl
and then install it with pip instead.
pip3 install youtube-dl
If you don't have pip3, you can install it with,
apt-get install python3-pip
or see this for more help on that.
The youtube-dl package in the apt repo for jessie(and maybe even trusty) hasn't been updated in almost a year.
Kasisnu
  • 540
Generally, 429 means that you may have downloaded too much. Practically, this is very common problem running youtube-dl on OVH/AWS/etc. You may want to workaround this by using --proxy or --source-address (see youtube-dl FAQ). You may also want to read this thread.
dstftw
  • 298
You can try adding '-4' or '-6' flags for forcing the download over IPv4 and IPv6 respectively. The video you were trying to download is unavailable now but the following command works for me :
youtube-dl -4 https://www.youtube.com/watch?v=sJFgo9H6zNo
You can refer this thread for more information.
