I downloaded the files from cisco (ubuntu installation files (with tutorial/student version)) and extracted the files. Yielding a folder Packettracer62Student. I ran the file install found in the folder. Agreed to the EULA, the script downloaded all the needed files. Basically everything´s working fine.
The problem is I want to uninstall packettracer and I can't find anything that works.
I already tried sudo apt-get remove --purge packettracer, and also dpkg -r packettracer. Both of which yielded that the package can´t be found. I tried to grep it in case it was named differently, still nothing.
What are my options in removing the software(package) of packettracer62?
Here is the ./install script that I used from the package:
(I´m sorry about the formatting, I will edit this as soon as I figure out how to properly input the script)
#!/bin/bash
# Thanks to Felix Wolf (felix@bar.bz) for providing this install script.
# Thanks to Paul Fedele for providing script to check/download 32-bit library on a 64-bit machine
initInstall ()
echo
echo Welcome to Cisco Packet Tracer 6.2 Installation
echo
echo Read the following End User License Agreement \"EULA\" carefully. You must accept the terms of this EULA to install and use Cisco Packet Tracer.
echo "Press the Enter key to read the EULA."
echo
read cont
more eula.txt
echo "Do you accept the terms of the EULA? (Y)es/(N)o"
echo
read input
case "$input" in
yes|YES|Yes|Y|y)
(installer);;
esac
exit 0
installer ()
SDIR=`dirname $_`
ARCHITECTURE=$(uname -m)
INSTALL_32BIT_LIBRARY=false
echo "You have accepted the terms to the EULA. Congratulations. Packet Tracer will now be installed."
read -p "Enter location to install Cisco Packet Tracer or press enter for default [/opt/pt]: " IDIR
if [ -z $IDIR ]; then
IDIR="/opt/pt"
fi
if [ $ARCHITECTURE = "x86_64" ]; then
DEPENDS=$(dpkg -l | grep yelp | tail -n 1 | cut -c1)
if [ $DEPENDS = "i" ]; then
TESTCONNECTION=`wget --tries=3 --timeout=15 www.cisco.com -O /tmp/testinternet &>/dev/null 2>&1`
if [ $? != 0 ]; then
echo -"You are not connected to the Internet. Please check your Internet connection and try again."; exit 0
else
INSTALL_32BIT_LIBRARY=true
fi
fi
fi
if [ -e $IDIR ]; then
read -p "It appears that Packet Tracer is already installed. Do you wish to replace it? [Yn] " NEEDREPLACE
if [ "$NEEDREPLACE" = "y" ] || [ "$NEEDREPLACE" = "Y" ] || [ -z $NEEDREPLACE ]; then
sudo rm -rf $IDIR
else
echo "Program Terminated"; exit 0
fi
fi
QIDIR=${IDIR//\//\\\\\/}
echo Installing into $IDIR
if mkdir $IDIR > /dev/null 2>&1; then
if cp -r $SDIR/* $IDIR; then
echo Copied all files successfully to $IDIR
fi
sh -c "sed s/III/$QIDIR/ $SDIR/tpl.packettracer > $IDIR/packettracer"
chmod a+x $IDIR/packettracer
sh -c "sed s/III/$QIDIR/ $SDIR/tpl.linguist > $IDIR/linguist"
chmod a+x $IDIR/linguist
if touch /usr/share/applications/pt6.desktop > /dev/null 2>&1; then
echo -e "[Desktop Entry]\nExec=PacketTracer6\nIcon=pt6\nType=Application\nTerminal=false\nName=Packet Tracer 6.2" | tee /usr/share/applications/pt6.desktop > /dev/null
rm -f /usr/share/icons/hicolor/48x48/apps/pt6.png
gtk-update-icon-cache -f -q /usr/share/icons/hicolor
sleep 10
cp $SDIR/art/app_student.png /usr/share/icons/hicolor/48x48/apps/pt6.png
fi
if [ "$INSTALL_32BIT_LIBRARY" = true ]; then
echo "Installing 32 bit libraries for Packet Tracer."
dpkg --add-architecture i386
apt-get -y install lib32z1
apt-get -y install lib32ncurses5
apt-get -y install lib32bz2-1.0
apt-get -y install libgcc1:i386
apt-get -y install libstdc++6:i386
apt-get -y install libssl-dev:i386
apt-get -y install libqtwebkit4:i386
apt-get -y install libqt4-scripttools:i386
fi
else
echo
echo Not able to create and copy files to $IDIR
read -p "Should we try to gain root access with sudo? [Yn] " QSD
if [ "$QSD" = "y" ] || [ "$QSD" = "Y" ] || [ -z $QSD ]; then
if sudo mkdir $IDIR; then
if sudo cp -r $SDIR/* $IDIR; then
else
echo
echo Not able to copy files to $IDIR
echo Exiting installation
exit
fi
sudo sh -c "sed s/III/$QIDIR/ $SDIR/tpl.packettracer > $IDIR/packettracer"
sudo chmod a+x $IDIR/packettracer
sudo sh -c "sed s/III/$QIDIR/ $SDIR/tpl.linguist > $IDIR/linguist"
sudo chmod a+x $IDIR/linguist
if sudo touch /usr/share/applications/pt6.desktop; then
echo -e "[Desktop Entry]\nExec=PacketTracer6\nIcon=pt6\nType=Application\nTerminal=false\nName=Packet Tracer 6.2" | sudo tee /usr/share/applications/pt6.desktop > /dev/null
sudo rm -f /usr/share/icons/hicolor/48x48/apps/pt6.png
sudo gtk-update-icon-cache -f -q /usr/share/icons/hicolor
sleep 10
sudo cp $SDIR/art/app_student.png /usr/share/icons/hicolor/48x48/apps/pt6.png
fi
sudo dpkg --add-architecture i386
sudo apt-get -y install lib32z1
sudo apt-get -y install lib32ncurses5
sudo apt-get -y install lib32bz2-1.0
sudo apt-get -y install libgcc1:i386
sudo apt-get -y install libstdc++6:i386
sudo apt-get -y install libssl-dev:i386
sudo apt-get -y install libqtwebkit4:i386
sudo apt-get -y install libqt4-scripttools:i386
fi
else
echo
echo Not able to gain root access with sudo
exit
fi
else
echo
exit
fi
fi
echo
echo
read -p "Should we create a symbolic link \"packettracer\" in /usr/local/bin for easy Cisco Packet Tracer startup? [Yn] " QC
if [ "$QC" = "y" ] || [ "$QC" = "Y" ] || [ -z $QC ]; then
if [ "$user" != "root" ]; then
sudo ln -sf $IDIR/packettracer /usr/local/bin
else
fi
echo "Type \"packettracer\" in a terminal to start Cisco Packet Tracer"
else
echo "Type \"$IDIR/packettracer\" in a terminal to start Cisco Packet Tracer"
fi
# add the environment var PT5HOME
sudo sh set_ptenv.sh $IDIR
echo
echo Cisco Packet Tracer 6.2 installed successfully
initInstall
exit 0
