From time to time, my Mail server stops sending any new mails, and i each time i find the blow error log,
Jun 22 23:10:18 myserver saslauthd[3967]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:18 myserver saslauthd[3971]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:19 myserver saslauthd[3972]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:19 myserver saslauthd[3968]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:20 myserver saslauthd[3969]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:20 myserver saslauthd[3967]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:21 myserver saslauthd[3971]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:21 myserver saslauthd[3972]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Jun 22 23:10:22 myserver saslauthd[3971]: DEBUG: auth_pam: pam_authenticate failed: Memory buffer error
Every time i have to restart myserver to work normally again
I also always find the below repeatitive error log from unknown IPs (i am not sure if it is related or not):
Jun 21 06:48:43 myserver sshd[1687]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=************  user=root
Jun 21 06:48:45 myserver sshd[1708]: Failed password for root from ######## port 60021 ssh2
Jun 21 06:48:47 myserver sshd[1708]: Failed password for root from ######## port 60021 ssh2
Jun 21 06:48:47 myserver sshd[1708]: Received disconnect from #######: 11:  [preauth]
Jun 21 06:48:47 myserver sshd[1708]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=************  user=root
Jun 21 06:48:47 myserver sshd[1730]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=************  user=root
Jun 21 06:48:48 myserver sshd[1732]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=============  user=root
Jun 21 06:48:48 myserver sshd[1730]: Failed password for root from ************ port 60094 ssh2
Jun 21 06:48:50 myserver sshd[1732]: Failed password for root from ============ port 40613 ssh2
Jun 21 06:48:50 myserver sshd[1730]: Failed password for root from ************ port 60094 ssh2
Jun 21 06:48:50 myserver sshd[1734]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=************  user=root
Jun 21 06:48:52 myserver sshd[1736]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=************  user=root
Jun 21 06:48:52 myserver sshd[1732]: Failed password for root from ============ port 40613 ssh2
Jun 21 06:48:52 myserver sshd[1730]: Failed password for root from ************ port 60094 ssh2
Jun 21 06:48:52 myserver sshd[1730]: Received disconnect from ***********: 11:  [preauth]
Jun 21 06:48:52 myserver sshd[1730]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=***********  user=root
Jun 21 06:48:52 myserver sshd[1734]: Failed password for root from ######## port 47803 ssh2
Jun 21 06:48:54 myserver sshd[1736]: Failed password for root from ######## port 55371 ssh2
Jun 21 06:48:54 myserver sshd[1732]: Failed password for root from ============ port 40613 ssh2
According to https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=758660 saslauthd stops functioning after some amount of logins (successful and/or failed).
You don't need to restart the whole server, the following is enough: service saslauthd restart
You can put that into a crontab. If a lot of logins originate from the same, malicious IP you can drop request from that IP in the firewall to make saslauthd last longer, e.g. iptables -A INPUT -s 185.29.11.6 -j DROP
mnagel
  • 995
