I tried to forward guest port 6379 to host 6379 and to 16379 but with no luck.
I can connect to redis from guest and set and get, and despite I also can connect to redis from host and get help, I cannot set or get.
I got no firewall running on guest, or host. Any help appreciated.
From host:
host: > redis-cli -h localhost -p 16379
localhost:16379> help
redis-cli 2.8.4
Type: "help @<group>" to get a list of commands in <group>
      "help <command>" for help on <command>
      "help <tab>" to get a list of possible help topics
      "quit" to exit
localhost:16379> help get
  GET key
  summary: Get the value of a key
  since: 1.0.0
  group: string
localhost:16379> get 'x'
Error: Connection reset by peer
localhost:16379> set 'x' 12
From guest:
vagrant:~$ redis-cli -v
redis-cli 2.8.4
127.0.0.1:6379> set 'x' 12
OK
127.0.0.1:6379> get x
"12"
zuba
  • 2,423
The solution is here : check your /etc/redis/redis.conf, and make sure to change the default
bind 127.0.0.1
to
bind 0.0.0.0
Then restart your service service redis-server restart
You can then now check that redis is listening on non-local interface with
zuba
  • 2,423
