I need to check the current version of VLC I have running, however I don't know where it is installed (can't see it in /etc or /bin).
If I do vlc in a terminal then the application starts, but is there a way to do like a pwd vlc command where it shows me the actual path of where the vlc app is being called from?
I want to see if the actual file name contains the software version since I can't find the version within the software itself.
I have a statement asking me to explain why this is different from another post. It is different because this is a 2 part question, where I am trying to understand the install package location (which is the same as the other link), however I also wanted to know how to check the VLC version, hence the title (and why this question is different).
heemayl
  • 93,925
john smith
  • 3,161
5 Answers5
Use the command :
vlc --version
Most of the programs (i have used) provide their version by the --version option.
Also you should check the man page of the commands to get details idea about them.
EDIT :
There are many ways to check where a binary file is stored, vlc in this case :
type -a vlc
command -v vlc
which vlc
heemayl
  • 93,925
Also other commands that can be found within different SE websites:
apt-show-versions vlc
But it has to be installed sudo apt-get install apt-show-versions then it will output for example:
vlc:i386/trusty 2.2.1~trusty uptodate
Using aptitude:
aptitude versions vlc
Will output the complete list/tree of packages related to vlc and the installed ones including the package vlc will contain letter "i"(meaning installed) before package name.
Similar but a bit shortened:
aptitude search vlc -F "%c %p %d %V"
And more programming one:
dpkg -l vlc | grep -E "^ii" | tr -s ' ' | cut -d' ' -f3
Will output 2.2.1~trusty
JoKeR
  • 7,062
You can check version of an installed Ubuntu package by running
dpkg -l | grep <package_name>
dpkg -l | grep vlc
It will give you versions of vlc-related packages.
To get path to vlc binary run
which vlc
But in Ubuntu it is very rarely needed to know where the binaries are located, if they are installed using dpkg or apt.
Pilot6
  • 92,041
simply start this command
apt-cache policy vlc
Sample output
vlc:
  Installed: 2.2.0-1
  Candidate: 2.2.0-1
  Version table:
 *** 2.2.0-1 0
        500 http://archive.ubuntu.com/ubuntu/ vivid/universe amd64 Packages
        100 /var/lib/dpkg/status
From man apt-cache
   policy [pkg...]
       policy is meant to help debug issues relating to the preferences file. With no arguments it will print out the priorities of each source. Otherwise it prints out detailed information about the priority selection of
       the named package.
And to check the installed files:
dpkg -L grep vlc
Sample output
/usr
/usr/lib
/usr/lib/mime
/usr/lib/mime/packages
/usr/lib/mime/packages/vlc
/usr/lib/vlc
/usr/lib/vlc/libvlc_vdpau.so.0.0.0
/usr/lib/vlc/plugins
/usr/lib/vlc/plugins/video_splitter
/usr/lib/vlc/plugins/video_splitter/libwall_plugin.so
/usr/lib/vlc/plugins/video_splitter/libclone_plugin.so
/usr/lib/vlc/plugins/video_splitter/libpanoramix_plugin.so
/usr/lib/vlc/plugins/codec
/usr/lib/vlc/plugins/codec/libvaapi_drm_plugin.so
/usr/lib/vlc/plugins/codec/libvaapi_x11_plugin.so
/usr/lib/vlc/plugins/codec/libsdl_image_plugin.so
/usr/lib/vlc/plugins/control
/usr/lib/vlc/plugins/control/libxcb_hotkeys_plugin.so
/usr/lib/vlc/plugins/visualization
/usr/lib/vlc/plugins/visualization/libglspectrum_plugin.so
/usr/lib/vlc/plugins/visualization/libvisual_plugin.so
/usr/lib/vlc/plugins/vdpau
/usr/lib/vlc/plugins/vdpau/libvdpau_deinterlace_plugin.so
/usr/lib/vlc/plugins/vdpau/libvdpau_avcodec_plugin.so
/usr/lib/vlc/plugins/vdpau/libvdpau_display_plugin.so
/usr/lib/vlc/plugins/vdpau/libvdpau_chroma_plugin.so
/usr/lib/vlc/plugins/vdpau/libvdpau_adjust_plugin.so
/usr/lib/vlc/plugins/vdpau/libvdpau_sharpen_plugin.so
/usr/lib/vlc/plugins/access
/usr/lib/vlc/plugins/access/librdp_plugin.so
/usr/lib/vlc/plugins/access/libpulsesrc_plugin.so
/usr/lib/vlc/plugins/access/libvnc_plugin.so
/usr/lib/vlc/plugins/access/libxcb_screen_plugin.so
/usr/lib/vlc/plugins/services_discovery
/usr/lib/vlc/plugins/services_discovery/libxcb_apps_plugin.so
/usr/lib/vlc/plugins/services_discovery/libpulselist_plugin.so
/usr/lib/vlc/plugins/video_output
/usr/lib/vlc/plugins/video_output/libgles2_plugin.so
/usr/lib/vlc/plugins/video_output/libaa_plugin.so
/usr/lib/vlc/plugins/video_output/libxcb_x11_plugin.so
/usr/lib/vlc/plugins/video_output/libglx_plugin.so
/usr/lib/vlc/plugins/video_output/libxcb_window_plugin.so
/usr/lib/vlc/plugins/video_output/libegl_x11_plugin.so
/usr/lib/vlc/plugins/video_output/libxcb_xv_plugin.so
/usr/lib/vlc/plugins/video_output/libgl_plugin.so
/usr/lib/vlc/plugins/video_output/libxcb_glx_plugin.so
/usr/lib/vlc/plugins/video_output/libcaca_plugin.so
/usr/lib/vlc/plugins/video_output/libgles1_plugin.so
/usr/lib/vlc/plugins/gui
/usr/lib/vlc/plugins/gui/libqt4_plugin.so
/usr/lib/vlc/plugins/gui/libskins2_plugin.so
/usr/lib/vlc/plugins/audio_output
/usr/lib/vlc/plugins/audio_output/libpulse_plugin.so
/usr/lib/vlc/plugins/misc
/usr/lib/vlc/plugins/misc/libxdg_screensaver_plugin.so
/usr/share
/usr/share/man
/usr/share/man/man1
/usr/share/applications
/usr/share/applications/vlc.desktop
/usr/share/kde4
/usr/share/kde4/apps
/usr/share/kde4/apps/solid
/usr/share/kde4/apps/solid/actions
/usr/share/kde4/apps/solid/actions/vlc-opencda.desktop
/usr/share/kde4/apps/solid/actions/vlc-openbd.desktop
/usr/share/kde4/apps/solid/actions/vlc-openvcd.desktop
/usr/share/kde4/apps/solid/actions/vlc-opendvd.desktop
/usr/share/lintian
/usr/share/lintian/overrides
/usr/share/lintian/overrides/vlc
/usr/share/bug
/usr/share/menu
/usr/share/menu/vlc
/usr/share/doc
/usr/bin
/usr/bin/svlc
/usr/bin/qvlc
/usr/share/man/man1/qvlc.1.gz
/usr/share/man/man1/svlc.1.gz
/usr/share/bug/vlc
/usr/share/doc/vlc
A.B.
  • 92,125
open the terminal and type the following command
type vlc command also includes the word 'type'
This gives you from where it was called .
For vlc version do vlc --version
jerry
  • 94
