I would use inotify API provided by the kernel to monitor filesystem events. There is no need for an indefinite while loop, you can use a tool that uses the interface provided by the kernel to check for any changes on any file.
One of the tools that uses inotify is inotifywait. From man inotifywait :
inotifywait efficiently waits for changes to files using Linux's inotify interface.
It is not installed by default, it is a part of inotify-tools package. You can install it by :
sudo apt-get install inotify-tools
The script i am taking about can take the form :
#!/bin/bash
while IFS= read -r line; do
parent="${line%% *}"
child="${line##* }"
new="${parent}${child}"
[[ -d $new ]] && touch "$new"/"$child".md
done < <(inotifywait --quiet --monitor --event CREATE,ISDIR /home/tim/test)
You can send it to the background :
./dir_event.sh &
Or perhaps use nohup or disown if you want :
nohup ./dir_event.sh &
inotifywait --quiet --monitor --event CREATE,ISDIR /home/tim/test is the command to monitor the file system events on directory /home/tim/test, we are only interested in CREATE and ISDIR events. We are saving (as line) and then manipulating every new line indicating a relevant event as they happen. Please check man inotifywait to get more idea.
parent will contain the directory we are monitoring /home/tim/test in this case and child will contain the newly created directory/file. Both are achieved by using bash parameter expansion.
new is addition of the two to get the absolute path to the newly created entry. As CREATE event will result in creating a file too we need to make sure that new is a directory.
[[ -d $new ]] checks if new is a directory, if so then we have created the required file inside it.
