I was copying 500 GB files from an external HDD to another external HDD and suddenly the local memory was running out?
When the copy was completed I rebooted and I get now a black screen. Logged in via SSH from another machine and the df -h command says :
Filesystem      Size  Used Avail Use% Mounted on
udev            3,9G     0  3,9G   0% /dev
tmpfs           801M  9,5M  792M   2% /run
/dev/sda1       213G  212G     0 100% /         <-----------------------
tmpfs           4,0G     0  4,0G   0% /dev/shm
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           4,0G     0  4,0G   0% /sys/fs/cgroup
tmpfs           801M     0  801M   0% /run/user/1000
And the du -sh command says :
du: cannot access ‘./proc/1945/task/1945/fd/4’: No such file or directory
du: cannot access ‘./proc/1945/task/1945/fdinfo/4’: No such file or directory
du: cannot access ‘./proc/1945/fd/3’: No such file or directory
du: cannot access ‘./proc/1945/fdinfo/3’: No such file or directory
212G
I don't get why the local HDD was affected by this as the file transfer involved only 2 external hard drives, caches ? temporary files ?
Obviously now I cannot delete large files as there aren`t any!
I copy the files through dolphin on Kubuntu 15.04 and maybe I should have done it via command line.
Can anyone help me with this and maybe explain me why?
Thanks
rf2632
  • 491
