Hey guys I'm having some issue with my rtl8188ee network card. On Windows I get ~30-40 Mb/s whereas on Ubuntu 15.04 I get ~5 Mb/s. However, the issue comes and goes; often after disconnecting and reconnecting my WiFi temporarily jumps to the proper speed, only to recede again shortly.
In search for an answer I came across this thread; however I was unable to properly compile the driver (here's the error I get when running make).
I was wondering if anyone knew how I could manage to compile the driver properly, or if anyone has another way to fix the slow WiFi speeds in Ubuntu 15.04.
In order to give as much information as possible, here are some diagnostic information:
uname --all:
Linux david-Lenovo-H535 3.19.0-21-generic #21-Ubuntu SMP Sun Jun 14 18:31:11 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
lshw -C network:
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 09
serial: c0:3f:d5:72:be:6c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168f-1_0.0.5 06/18/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:46 ioport:e000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
*-network
description: Wireless interface
product: RTL8188EE Wireless Network Adapter
physical id: 0
bus info: pci@0000:04:00.0
logical name: wlan0
version: 01
serial: 28:e3:47:60:76:6f
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8188ee driverversion=3.19.0-21-generic firmware=N/A ip=10.0.0.14 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:48 ioport:d000(size=256) memory:fea00000-fea03fff
some guy's wireless info script
Edit
I successfully installed the new driver thanks to @Pilot6 but problem persists. For more information, my download is the only speed affected. Upload is consistent at 10 Mb/s. I really have no clue what to do at this point. I know the hardware is fine because in Windows I don't have any issues with wireless.
Second Edit
Disabling IPv6 worked for a while but speeds dropped back down again. Problem remains intermittent. I don't think this has to do with the wireless repeater I'm using because all other devices work fine. Further, upload speeds have been entirely consistent, so I doubt it has to do with the signal or interference.
Alas, 5 Mb/s is sufficient for my daily routine. I only hope a future update will solve the problem.
