I get this error message when I'm trying to mount my Windows' drives through a file manager which would otherwise mount the partitions automatically. How to fix this?
                Unable to access “New Volume”
Error mounting /dev/sda3 at /media/archisman/New Volume:
Command-line `mount -t "ntfs" -o
"uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sda3" "/
media/archisman/New Volume"' exited with non-zero exit status 14:
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda3': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
I am a Linux newbiw and hence I do not know about the more technical details of the situation. Please help. Plus, I have repeatedly shut down my Windows 8.1 properly without hibernating it or anything.
PS.- I'm using the Gnome Desktop Environment, if it is of any concern.
using the following command , get info about your drives
sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
Then mount the drives using following command
sudo ntfsfix /dev/sda1
Here sda1 i used as example , replace sda1 with corresponding sda number ,command 1 gives the sda number of your drive
and remember windows drives are of ntfs partition
Maythux
  • 87,123
jerry
  • 94
