I have problem when I implemented this command
sudo apt-get install tcl8.5-dev tk8.5-dev
And I get this:
fawaz@fawaz-Lenovo-B590:~$ sudo apt-get install tcl8.5-dev tk8.5-dev
Reading package lists... Done
Building dependency tree
 tcl8.5-dev : Depends: tcl8.5 (= 8.5.11-1ubuntu1) but it is not going to be installed
 tk8.5-dev : Depends: libx11-dev but it is not going to be installed
             Depends: libxss-dev but it is not going to be installed
             Depends: libxext-dev but it is not going to be installed
             Depends: libxft-dev but it is not going to be installed
             Depends: tk8.5 (= 8.5.11-1) but it is not going to be installed
PLZ help me
kyodake
  • 17,808
user426267
Enter the following commands into the terminal:
sudo apt-get update
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
Then enter:
sudo apt-get install tcl8.5 libx11-dev libxss-dev libxext-dev libxft-dev tk8.5.11-1
Now try installing tcl8.5-dev and tk8.5-dev again:
ntninja
  • 736
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
