I am new here. Please make it easy for me to understand.
Recently I installed Ubuntu 10.04 netbook edition inside windows using Wubi with ultra ISO and magic iso virtual manager in my GREAT WALL A081 netbook....The problem is that when I start Ubuntu the screen gets distorted and blurred. I have tried the debugging mode using failsafeX. In failsafeX Ubuntu starts with an error that "SCREEN, GRAPHIC CARD AND INPUT DEVICES ARE NOT DETECTED, YOU HAVE TO DEBUG THEM"
Please Help Me!
My netbook specification is given below :
Processor: Mobile VIA C7-M 1600MHz
Cache: 128KB L2
Chipset: VIA CN896NB
RAM: 512MB
Graphics Card: Integrated VIA S3G UniChrome Pro, 64MB
Screen: 10.2 inches TFT WXGA (1024 × 600)
Hard Drive: 120G
Wireless: VIA Networking Technologies
Networking: Realtek RTL8139 Family
Battery: 2200mAh
Dimensions: 249mm (L) x 178mm (W) x 38.5mm (H)
Weight: 1221.5g (default)
Operating system: WinXP
i tried the following
Section "Device"
    Identifier  "Configured Video Device"
    Driver      "openchrome"
EndSection
Section "Monitor"
    Identifier  "Configured Monitor"
EndSection
Section "Screen"
    Identifier  "Default Screen"
    Monitor     "Configured Monitor"
    Device      "Default configured Device"
EndSection
(The screen became unstable as b4)
my Xrandr -q
Screen 0: minimum 640 x 480, current 1280 x 720, maximum 1280 x 720
default connected 1280x720+0+0 0mm x 0mm
   1280x720        0.0*
   1024x600        0.0
   800x600        61.0
   720x576         0.0
   720x540         0.0
   720x480         0.0
   640x480        60.0
My cvt for 1024x600
# 1024x600 59.85 Hz (CVT) hsync: 37.35 kHz; pclk: 49.00 MHz
Modeline "1024x600_60.00"   49.00  1024 1072 1168 1312  600 603 613 624 -hsync +vsync
i tried with nomodeset at the grub and openchrome at the xorg.conf but same old result - distorted and hundreeds of lines in the screen.
My xrandr is
   1280x720        0.0*
   1024x600        0.0
   800x600        61.0
   720x576         0.0
   720x540         0.0
   720x480         0.0
   640x480        60.0
   1024x600_60.00   59.9
   1024x600_6O.OO   59.9
commands are :
 xrandr --newmode  "1024x600_60.00"   49.00  1024 1072 1168 1312  600 603 613 624 -hsync +vsync
xrandr --addmode default 1024x600_60.00
xrandr --output default --mode 1024x600_60.00
When i press enter after typing the xrandr --output...... it gives error "crct 0 failed"
fossfreedom
  • 174,526
At last by working 3 ni8s....i think we have done it.....thanksssss guys..specially fossfreedom....
The solution of the problem is found by experimenting it....huh big relief Thanks again for your help
Section "Monitor"
EndSection
Section "Screen"
        Device      "configured Video Device"
        SubSection "Display"
                Virtual 1024 600
        EndSubSection
EndSection
Section "Device"
        Driver      "vesa"
EndSection
fossfreedom
  • 174,526
It is very likely that your graphics issues are due to the VIA graphics chipset which are not very well supported in linux.
Two possible suggestions:
  1. Boot with one or more "grub boot options" - nomodeset & xforcevesa
  2. Use a custom xorg.conf file with device names such as fbdev, vesa
I've recently answered a similar question below - can I suggest you have a look at this and try out some of the possible solutions described there.
Once you've found the correct "device" to get stable graphics the next task is to define the resolution most appropriate to your laptop.
Firstly I would check that a resolution most appropriate is not already available - from your menu choose "system - preferences - monitors".
See if a resolution is available that you can use.
If not you will need to define a resolution most appropriate to your laptop.
Fortunately there are many similar questions on this site - I've picked one that you should try below.
The principle behind the answer is the same -
  • run xrandr -q to see the default resolutions.
  • run cvt with an appropriate resolution (e.g. cvt 800 540 )
  • run xrandr to test this resolution - check in the Monitors applet in your
  • preferences menu.
  • add a successful resolution to .xprofile
  1. Unsupported Video Chipset - How do I force Low-Graphics mode?
  2. Unknown monitor, intel driver, want to set VGA resolution to widescreen TV
fossfreedom
  • 174,526
