I have acer laptop with windows 8.1. I tried installing ubuntu 14.04 from bootable usb drive alongside windows. I changed bios settings from UEFI to LEGACY and secure boot from ENABLED to DISABLED. I chose option "INSTALL ALONGSIDE OTHER OPREATING SYSTEM" I got error message "Installer crashed" after the partition screen. What do I need to do to install ubuntu successfully? thanks,
Asked
Active
Viewed 802 times
There are a few things that you will need to do here.
- Set your boot back to UEFI, or normal
- Download Rufus - to create a bootable USB device
- Boot to your USB by clicking F8 at startup to access boot options - or F1 to enter BIOS setup to set USB as first boot
- Now continue with the installer as normal
There are so many issues with running your boot in Legacy. I tried it on my laptop just to see what would happen and I could never get Ubuntu to install.
I always recommend setting up partitions manually (if you know how) as well, and install from that route. This way you can choose the file extensions for each partition and designate the amount of disk space to each partition.
Joe
- 149
- 9
