For me it was a different thing resulting in this error
same username with two different UIDs
I have user "apache" configured locally with UID=123 and in NIS directory with the same name ("apache") but different UID=456.
Depending on the start order and service dependency, local user might be used before NIS user is avaiable. That also means, when you display usernames, this will be confusing, both will appear as "apache". Only when you look at numerical UIDs (for example by doing ls -ln you will see the difference.
Example:
[root@mymachine]# ls -l
drwxr-x--- 4 apache ggg1 88 May 31 17:12 file1
drwxr-x--- 4 apache ppp2 88 May 31 17:12 file2
see the UID is different for file2 (456 instead of 123):
[root@mymachine]# ls -ln
drwxr-x--- 4 123 48 88 May 31 17:12 file1
drwxr-x--- 4 456 48 88 May 31 17:12 file2
different group defined in Apache config
Another problem that I had with user mismatch and resulting permission error, was when I was restricting access to files by using group "httpd". This was the primary group of user "apache" (that was displayed using id or getent)
Apache starts as root, then switches to configured user and drops permission. The user it switches to is defined in /etc/httpd/conf/httpd.conf by User parameter.
Here is the problem though - the group (GID) which the process will be running as is NOT the primary group of that user. The group is defined in the same config file by Group parameter.
So in my case it was (/etc/httpd/conf/httpd.conf):
User apache
Group apache
And the directory was granted access like this:
drwxr-x--- 4 someuser httpd 88 May 31 17:12 mydir
Because httpd (GID=444) was the primary group of that user:
[root@somemachine]# id apache
uid=48(apache) gid=444(httpd) groups=444(httpd)
It resulted in some time spent debugging until I realized that Group in config file was "apache" not "httpd".
Error from /var/log/httpd/error_log:
[Fri May 31 17:13:40.070343 2019] [authz_core:debug] [pid 2527] mod_authz_core.c(809): [client 11.22.32.21:53824] AH01626: authorization result of Require all granted: granted
[Fri May 31 17:13:40.070367 2019] [authz_core:debug] [pid 2527] mod_authz_core.c(809): [client 11.22.32.21:53824] AH01626: authorization result of <RequireAny>: granted
[Fri May 31 17:13:40.070396 2019] [core:error] [pid 2527] (13)Permission denied: [client 11.22.32.21:53824] AH00132: file permissions deny server access: /var/www/html/somedir/otherdir/css/file1.txt
I hope this helps.
