I want to do a fresh install on my computer. I have an intel 64 bit CPU. I am wondering can I install this version: ubuntu-14.04.2-desktop-amd64.iso
I really want to install the 64 bit version. But the name contains amd, so I am not sure if it's compatible with my machine. Thank you!
Maythux
  • 87,123
AMD64 is the same as x86-64, just another name for the same architecture - it doesn't have to do anything with actual cpu vendor.
Quoted from https://en.wikipedia.org/wiki/X86-64:
x86-64 (also known as x64, x86_64 and AMD64) is the 64-bit version of the x86 instruction set
The original specification was created by AMD, and has been implemented by AMD, Intel and VIA. Various names are used for the instruction set; prior to the launch, x86-64 and x86_64 were used, while upon the release AMD named it AMD64
Quoted from https://askubuntu.com/a/84775/150504
It's merely a convention due to the fact that AMD created the 64-bit extensions to the x86 (Intel 386/486/Pentium) instruction set. At that time, Intel was pushing Itanium as the only 64-bit solution, and Intel didn't copy AMD's extensions until it was clear that AMD had created something that was being used widely. The #define AMD64 was used to distingish this 64-bit instruction set from Intel's Itanium instruction set.
Maythux
  • 87,123
Yes, you can install it - amd64 (sometimes called x64) is the name of the architecture and it's not made specifically for AMD CPUs.
