I'm running Ubuntu 14.04 on a MacBook, and am considering installing TLP to improve battery life/overheating.
But I'm curious if it will change brightness settings/Internet or Bluetooth functionality, things like that.
Anything I would notice or could potentially annoy me? I'm hoping it's just a somewhat silent background program, is this the case?
Maythux
  • 87,123
cosmoflop12
  • 1,189
  • 15
  • 24
From what I've read, It looks like TLP will disable WiFi and Bluetooth until needed, and it also controls brightness.
Quick answer: yes.
Daniel
  • 3,626
  • 24
  • 46
Quoted from http://www.webupd8.org/2013/04/improve-power-usage-battery-life-in.html
TLP applies these settings automatically on startup and every time you change the power source. To use it, all you have to do is install TLP, however, there are some settings that you can apply manually, overwriting the TLP default settings, such as enabling or disabling the WiFi, Bluetooth or Wwan (3G or UMTS) radios, switching between AC or battery settings, ignoring the actual power source, apply autosuspend for all attached USB devices or power off the optical drive.
As a conclusion it will affect wifi,bluetooth, Wwan, ... and need some manual configuration.
If you prefer some daemon apps for controlling overheat, then try installing thermald with
sudo apt-get install thermald
Quoted from https://wiki.ubuntu.com/Kernel/PowerManagement/ThermalIssues
Thermald
The thermald daemon prevents machines from overheating and was introduced in
the 14.04 Ubuntu Trusty LTS release. It monitors thermal sensors and will
modify cooling controls to keep the hardware cool. Thermald uses the
available CPU temperature sensors and will keep the CPU from overheating. If
hardware supplies a skin temperature sensor then by default thermald will
endeavour to keep the skin temperature under 45 degrees C.
Maythux
  • 87,123
