The current enabled TLS on my server is "tls 1", how can i enable tls 1.2 on my ubuntu server, and do i have to upgrade my openssl first?
# apache2ctl -v
Server version: Apache/2.2.12 (Ubuntu)
# openssl version -a
OpenSSL 0.9.8g 19 Oct 2007
built on: Fri Dec  3 23:05:00 UTC 2010
platform: debian-amd64
options:  bn(64,64) md2(int) rc4(ptr,char) des(idx,cisc,16,int) blowfish(ptr2)
compiler: gcc -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -m64 -DL_ENDIAN -DTERMIO -O3 -Wa,--noexecstack -g -Wall -DMD32_REG_T=int -DMD5_ASM
In order to use TLSv1.1 and TLSv1.2 for SSLProtocol, you need at least version 2.2.23 (in addition to OpenSSL 1.0.1 or higher).
Once you have the latest,
Add
SSLProtocol TLSv1.1
to
/etc/httpd/conf.d/ssl.conf
Won Jun Bae
  • 141
First step is, you will have to upgrade your OpenSSL version to 1.0.1 or higher. Your current OpenSSL version does not support TLS 1.2.
