43
I've installed VirtualBox (with Ubuntu 14.04 Desktop) and Guest Additions on my Windows 7 machine.
Every time it boots up I get the following error message which goes away:
vboxclient the virtualbox kernel service is not running. exiting.
How can I disable this message? I've tried the following:
I deleted /etc/xdg/autostart/vboxclient.desktop file.
But I am still seeing the message when logging in.
Any suggestions on how to fix this?
d a i s y
  • 5,551
5 Answers5
30
This usually happens when you update the Guest's Linux Kernel.
After each update, you need to do:
  • For Host (installing server)
    sudo /etc/init.d/vboxdrv setup
  • For Guest (installing additions)
    sudo /etc/init.d/vboxadd setup
The reason why inserting the VBox addition disk again works is because that's one of the things the installation procedure does as well.
d a i s y
  • 5,551
Delete
  • 728
29
Try eject the VBOXADDITIONS cd image on ubuntu and "insert" it again from Vbox menu. I was just having this same problem and doing this fixed it.
Christopher
  • 306
I'm running Ubuntu 15.04 on Virtualbox 5.02. The same notification went away after I selected two "restricted drivers" from Virtualbox.
More specifically, from Software & Updates > Additional Drivers tab, there are two drivers previously not selected: Using x86 virtualization solution - X11 guest utilities from virtualbox-guest-x11 and Using x86 virtualization solution - guest addition module source for dkms from virtualbox-guest-dkms. The notification was gone after I selected to use these two proprietary drivers.
Update: one of these two drivers seem to cause a repository inconsistency when I run apt-get update. I chose to use the package maintainer's version to solve the inconsistency, and haven't run into any further problem.
Zanna
  • 72,312
Samuel Li
  • 759
If you just want to prevent this warning from showing when you boot up your system, follow the description here: Look for the file 98vboxadd-xclient (e.g. /etc/X11/Xsession.d/98vboxadd-xclient) and comment out line 26 giving the warning as shown below:
if ! test -c /dev/vboxguest 2>/dev/null; then
   # Do not start if the kernel module is not present.
   # notify-send "VBoxClient: the VirtualBox kernel service is not running.  Exiting."
(Works on Ubuntu 16.04.)
fuenfundachtzig
  • 356
  • 13
Pay attention to the purge command which deletes configuration files
sudo apt-get purge virtualbox-guest-x11 virtualbox-guest-utils virtualbox-guest-dkms
I've found it here
oneself
  • 275
