Alternative way to earn the bounty: Show me how to store a file system like ext4 (a FS which can store large files, I don't really need all of the good stuff ext4 provides for this use case) in many small files (< 4 GiB) stored on a (working) FAT-formatted partition.
I have an SD card (adverties as 64 GB but other than usual storage media has less than that (it has 63'416'827'904 Byte)) and an SD slot on my laptop (an Acer Aspire VN7-591G-70CY). The SD card worked with my previous laptop without problems and is formatted with ext4.
I tried sudo modprobe -r r852; sudo modprobe -r sdhci_pci; sudo modprobe r852; sudo modprobe sdhci_pci which helped others but did nothing for me.
The SD card works with an SD card to USB adapter. When using this adapter the SD card is /dev/sdb and the single partition on it is /dev/sdb1. When I put it into the SD card slot it is /dev/mmcblk0 and its partition is /dev/mmcblk0p1.
When I enter the SD card into the slot, nautilus says:
Error mounting /dev/mmcblk0p1 at /media/christoph/e07d3be4-bd85-4eb2-9205-d6638ab37704: Command-line `mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/mmcblk0p1" "/media/christoph/e07d3be4-bd85-4eb2-9205-d6638ab37704"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/mmcblk0p1, missing codepage or helper program, or other error
   In some cases useful info is found in syslog - try
   dmesg | tail or so.
Mounting it manually results in pretty much the same error message:
   dmesg | tail or so.
Now the weird part is that dd doesn't seem to work in either case. I copied the first 100 MiB of each /dev/sdb, /dev/sdb1, /dev/mmcblk0 and /dev/mmcblk0p1 and earlier this day even got matching sha256-sums.
They now don't match any more but are very similar in the way that except for a little bit in the beginning almost exclusively consist of zero bytes even though the SD card is almost entirely full (and filled with compressed and encrypted data, so there shouldn't me many zero bytes).
So I replaced every instance of 4 consecutive zero bytes in $mmcblk0 (the copies I made via dd are named exactly the same as the devices but I but a dollar sign before the name so they can be differentiated) with plain nothingness in a hex editor and ended up with files just being 129.4 kB for r$sdb (the 'r' is for 'reduced' / 'replaced') and 312.7 kB for r$mmcblk0 instead of being 104.9 MB each.
r$sdb has a mount point stated in the beginning (and I have no idea why). It really is the mount point the SD card was mounted on. Then comes randomly seeming data with a lot of repetitions, followed by a whole lot of FF bytes, followed by actual names of files saved on the SD card, followed by a little more randomly seeming data but not much.
About the fist 1600 Byte in r$mmcblk0 are exactly the same as in r$sdb (this includes the mount point even though the SD card couldn't be mounted while in the slot). Then comes randomly seeming data with a lot of repetitions but with big blocks made from printable characters including file paths, followed by FF bytes, followed by exactly the same as the ending of r$sdb (actual names of files saved on the SD card, followed by a little more randomly seeming data but not much).
Can you help me to resolve the problem and maybe tell me why dd outputs this weird data?
I figured out how to make it work with FAT myself. I ran apt-get install nfs-common, rebooted and now FAT is working. Unfortunately, FAT is a shitty file system which doesn't support loads of stuff and I need file many GB in size which aren't supported by FAT. So I cannot use the SD card with FAT at all.
If I format the partition with ext4, the same error as previously occurs. For FAT everything seems fine.
Is there a command to make it work for ext4 as well?
$ sudo fdisk -l
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 2D8D2D1D-B17D-4F86-ACD1-743E6B376EFE
Device          Start        End    Sectors   Size Type
/dev/sda1        2048    1230847    1228800   600M Windows recovery environment
/dev/sda2     1230848    1845247     614400   300M EFI System
/dev/sda3     1845248    2107391     262144   128M Microsoft reserved
/dev/sda4  1716043776 1920843775  204800000  97.7G Microsoft basic data
/dev/sda5  1920843776 1953523711   32679936  15.6G Windows recovery environment
/dev/sda6     2107392   36923391   34816000  16.6G Linux swap
/dev/sda7    36923392 1716043775 1679120384 800.7G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/mmcblk0: 59.1 GiB, 63416827904 bytes, 123860992 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xd69abc36
Device         Boot Start       End   Sectors  Size Id Type
/dev/mmcblk0p1       2048 123860991 123858944 59.1G 83 Linux
Disk /dev/mapper/cryptswap1: 16.6 GiB, 17825267712 bytes, 34814976 sectors
$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 860M] (rev a2)
07:00.0 Network controller: Intel Corporation Wireless 7265 (rev 48)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
I think that the last part of the output of dmesg is interesting:
[10106.153215] mmc0: new ultra high speed SDR50 SDXC card at address 59b4
[10106.153349] mmcblk0: mmc0:59b4 SD    59.0 GiB
[10106.158564]  mmcblk0: unknown partition table
[10109.748018]  mmcblk0: p1
[10110.393758] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[10111.098030] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[10111.862596] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[10111.862610] EXT4-fs (mmcblk0p1): Magic mismatch, very weird!
[10201.953257] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[10202.553754] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[10202.555661] EXT4-fs (mmcblk0p1): ext4_check_descriptors: Checksum for group 48 failed (26727!=0)
[10202.555664] EXT4-fs (mmcblk0p1): group descriptors corrupted!
UTF-8
  • 5,910
  • 34
  • 68
In my opinion, your SD Card Reader is failing. There is a very high probability of data loss. FAT is working probably because it has less error checking features, but that doesn't mean no errors! Use FAT with extreme caution. Take backups if you will be storing important data. Or rather, don't store important data, or simply use the USB Card Reader. That being said,
Try repairing your SD card which is a standard procedure:
sudo e2fsck -f -C 0 /dev/mmcblk0p1
e2fsck is the linux utility to repair ext based filesystems. Anyways, I don't expect it to work.
So, as another answer suggests, the card reader might not support such a large drive. But the fact that FAT works indicates that it is possible, with the added possibility of getting screwed up.
These are things you can try, but I don't know if they will work: Partition it into two, or even four drives if it will suit you, and then go forward with ext4. Or how about creating a smaller partition and leaving the rest as free space? You could give it a try.
Finally, since FAT works, (remember, probably because it does little error checking) exFAT could meet your requirements of storing file sizes greater than 4 GB. See how to do it here.
daltonfury42
  • 5,559
I believe the problem is caused by the fact that this particular SD cardreader is unable to read SD cards that have a 64 GB capacity while the other one in your previous laptop apparently can read such cards. Not all card readers have the same specifications. When you buy a card reader it is stated in the documentation what the biggest capacity is that the reader can handle. When it sits already in a laptop you'll have to figure it out what it can handle. Currently the limit is usually 32 GB. Unfortunately you can't change this property.
wie5Ooma
  • 1,849
Considering the new information you've added to the question I've a different approach for you.
In GParted format the partition on the card as ext4. Then create a mountpoint. Let's assume this is sd. So you do:
mkdir -p /media/sd.
Then to mount it you do:
mount -t ext4 -O noatime,nodiratime /dev/mmcblk0p1 /media/sd.
The second command above is supposed to be on one line. Probably you have to prepend these commands with sudo. You can also use the flags in the second command in /etc/fstab.
wie5Ooma
  • 1,849
