I wanna install ubuntu mate desktop 14.04 LTS on Raid 1 - preferably with LVM and Encryption.
tha farthest i got so far is. booting live system installing mdadm, creating a raid starting installation. (then i wanted to use brtfs instrat of ext - and i screwed everything up so that i couldnt start the installation) at the second try with just leaving the defaults it worked it just could not install grub - i told to try it again and it seemed to work (there was no error message) but it did not boot. - the thing is (i think) how will the freshly installed system know that it is a raid - because if i goo to boot option in bios i of course still see both disks seperately and no raid - where should it try to boot from. (it didnt worked either way)
other question i have is if i need for the raid to be synced to start the installation.
i've read the thing with alternate isntallation but this is not available anymore - and i want to avoid installing server - but i think this is the next thing im goint to try.
i just tried to install ubuntu on one disk (suceed ^^) and now add the seccond - but with the normal commands to create a new raid at least the first disk (od course) is busy and im afraid the system will freeze if i deactivate it ^^
ok therefore i will just tr this now https://www.howtoforge.com/how-to-set-up-software-raid1-on-a-running-system-incl-grub2-configuration-ubuntu-10.04
if anything has already experience with what im tryin to do. - please help me :D
I did something similar, but without LVM and encryption. You may perhaps still find something from the instructions here, especially if your system boots via EFI.
