I tried to change my touchpad settings by using these commands:
xinput set-prop "SynPS/2 Synaptics TouchPad" "Synaptics Finger" 50 90 255
xinput set-prop "SynPS/2 Synaptics TouchPad" "Synaptics Noise Cancellation" 20 20
but then I have to press much harder for touchpad to work. Is it possible to reset these settings?
Maythux
  • 87,123
Hobroker
  • 123
All what you have to do is a system reset(reboot) since all done by xinput is not permanent, which means all of your work is gone when you reboot, so you just have to do that.
To make xinput permanent refer to those:
Maythux
  • 87,123
The only workaround I've found is to disconnect and then reconnect the device. Remember that if this is a wireless mouse or the like, you'll likely need to disconnect the dongle or Bluetooth device and then reconnect/add it.
