I'm having some trouble with my WiFi connection for some odd reason. This is my second time installing Ubuntu 14.04 LTS, which the first time I remember having the same problem, but I managed to fix it somehow. Aside from that, I connect to the WiFi perfectly fine, however my download speed is absolutely horrendous. I used to get anywhere from 500kb/s - 1.9mb/s on Windows 8.1 and my first installation of Ubuntu 14.04 LTS, but now it's ranging from a minimum of either nothing to a max 200kb/s, which is absolutely frustrating as you could imagine. I've tried a number of methods to try to fix it, but not one of them helped the issue at all. If I need to list my specs and whatnot, please tell me the command(s) to use in terminal to get them, and I will gladly post them. Thanks!
Asked
Active
Viewed 62 times
Did you follow the general fixes like disabling ipV6, 8011n and power management. ?
If not read this post
Unfortunately WiFi issue is most commonly encountered in Ubuntu. But there are guidelines to fix it. And you should find them in the above link
Trinadh venna
- 158
- 1
- 1
- 6
