I just bought an Acer Aspire VN7-591G-70CY (4k display version) and installed Ubuntu after disabling UEFI and using this (nomodeset). It didn't work with UEFI enabled.
In the live session and with the installed OS the bottom of the screen (about as high as the trash icon in the launcher, I only can see its top) keeps always black. It's black already in grub.
I tried to figure out whether it has something to do with UEFI (the preinstalled Windows 8 only boots with UEFI) but I couldn't get Ubuntu to boot with UEFI. When selecting UEFI in the bios settings, Windows Boot Loader appears in the boot mediums (for whatever reason). I made sure to place the HDD above the Windows Boot loader but it goes straight to Windows and doesn't load grub. With an USB stick I can't get Ubuntu to boot any further than to the Ubuntu logo with the dots under it. I also can't manage to do the change of settings as explained by the thread linked to above because the part when I could change the settings is skipped.
I also tried to figure out whether this can be cured by installing additional graphics drivers but none helped and some prevented me from logging in via GUI (neither into my account nor into the guest account, logging in via a TTY, however, worked and that's how I removed the driver afterwards).
I don't care at all whether I can use Windows or not, I just want the black stripe to vanish.
UTF-8
  • 5,910
  • 34
  • 68
I just solved the problem and don't want to delete the question because I think this could be interesting for other people as well.
I simply changed
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX="quiet splash acpi_osi=Linux acpi_backlight=vendor"
in /etc/default/grub, ran sudo update-grub rebooted and the problem was resolved. :)
UTF-8
  • 5,910
  • 34
  • 68
