I have been asked to write a command that appends the n-th line (MYN) from a file (x)to another file (y). Here's what I've done so far:
MYN=4
hey=$(awk 'NR==$MYN' x)
echo "$hey" >> y
But why doesn't this work?
MYN=4
echo "$hey" >> y
I see your problem, you're using single quotes. They won't allow the Bash variable $MYN to expand. You can complicate things by telling awk a new variable, or because it's so simple, you can just switch to double-quotes:
awk "NR==$MYN" x
I'd have used sed but I can't see any obvious issues with your logic
MYN=4
sed "${MYN}q;d" x >> y
It seems to work as expected:
$ for i in $(seq 1 10); do echo $i >> x; done
$ sed "${MYN}q;d" x
If your goal is to pass a variable to awk in order to use it within the script, you can use awk with the -v option:
hey=$(awk -v MYN=$MYN 'NR==MYN' x)
