I have tried to upgrade my apache2.2 to apache2.4 and php5.3 to php5.5 on my Ubuntu 12.04. For php5.5 I have used those commands below (I dont remember which PPA i used for apache upgrade) :
add-apt-repository ppa:ondrej/php5
add-apt-repository ppa:ondrej/php5-oldstable
apt-get update
apt-get install php5
apt-get install python-software-properties
Than I tried to downgrade it by removing PPAs with :
sudo add-apt-repository --remove ppa:ondrej/php5-oldstable
apt-get update
But it gave me this output with some errors :
libapache2-mod-php5 : Depends: php5-common (= 5.5.26+dfsg-1+deb.sury.org~precise+1) but 5.3.10-1ubuntu3 is to be installed
php5 : Depends: php5-common (>= 5.3.10-1ubuntu3.18) but 5.3.10-1ubuntu3 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
So once I issued the command 'apt-get -f install' I get this :
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages will be REMOVED:
libapache2-mod-php5
0 upgraded, 0 newly installed, 1 to remove and 119 not upgraded.
1 not fully installed or removed.
After this operation, 9473 kB disk space will be freed.
Do you want to continue [Y/n]? y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_PAPER = "tr_TR.UTF-8",
LC_ADDRESS = "tr_TR.UTF-8",
LC_MONETARY = "tr_TR.UTF-8",
LC_NUMERIC = "tr_TR.UTF-8",
LC_TELEPHONE = "tr_TR.UTF-8",
LC_IDENTIFICATION = "tr_TR.UTF-8",
LC_MEASUREMENT = "tr_TR.UTF-8",
LC_TIME = "tr_TR.UTF-8",
LC_NAME = "tr_TR.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up php5-fpm (5.3.10-1ubuntu3) ...
start: Job failed to start
invoke-rc.d: initscript php5-fpm, action "start" failed.
dpkg: error processing php5-fpm (--configure):
subprocess installed post-installation script returned error exit status 1
php5-fpm
I have checked my sourcelists by commands below. They gave no output, so I thought those PPAs removed successfully.
cat /etc/apt/sources.list.d/*.list
cat /etc/apt/sources.list | grep php
cat /etc/apt/sources.list | grep apache
Also :
dpkg -l |grep php
gave me this :
ii dh-php5 0.2+deb.sury.org~precise+1 debhelper add-on to handle PHP PECL extensions
ii libapache2-mod-php5 5.5.26+dfsg-1+deb.sury.org~precise+1 server-side, HTML-embedded scripting language (Apache 2 module)
ii php-pear 5.3.10-1ubuntu3 PEAR - PHP Extension and Application Repository
ii php5 5.3.10-1ubuntu3 server-side, HTML-embedded scripting language (metapackage)
rc php5-apcu 4.0.6-1+deb.sury.org~precise+1 APC User Cache for PHP 5
ii php5-cli 5.3.10-1ubuntu3 command-line interpreter for the php5 scripting language
ii php5-common 5.3.10-1ubuntu3 Common files for packages built from the php5 source
iF php5-fpm 5.3.10-1ubuntu3 server-side, HTML-embedded scripting language (FPM-CGI binary)
ii php5-gd 5.3.10-1ubuntu3 GD module for php5
ii php5-imagick 3.1.0~rc1-1 ImageMagick module for php5
rc php5-json 1.3.6-1+deb.sury.org~precise+1 JSON module for php5
ii php5-mcrypt 5.3.5-0ubuntu1 MCrypt module for php5
ii php5-mysql 5.3.10-1ubuntu3 MySQL module for php5
ii phpmyadmin 4:3.4.10.1-1 MySQL web administration tool
ii pkg-php-tools 1.21+deb.sury.org~precise+1 various packaging tools and scripts for PHP packages
I have also tried to re-add PPAs and removed them with ppa-purge :
ppa-purge ppa:ondrej/php5-oldstable
But after remove of PPAs, it gave this output with some errors :
Updating packages lists
PPA to be removed: ondrej php5-oldstable
comm: file 2 is not in sorted order
Package revert list generated:
dh-php5/precise libapache2-mod-php5/precise libbsd0/precise libedit2/precise
php-pear/precise php5/precise php5-cli/precise php5-common/precise
php5-fpm/precise php5-gd/precise php5-imagick/precise php5-mcrypt/precise
php5-mysql/precise
Disabling ondrej PPA from
/etc/apt/sources.list.d/ondrej-php5-oldstable-precise.list
libedit2 is already the newest version.
libapache2-mod-php5 is already the newest version.
libbsd0 is already the newest version.
dh-php5 is already the newest version.
Selected version '0.2+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [all]) for 'dh-php5'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'libapache2-mod-php5'
Selected version '0.7.0-2+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'libbsd0'
Selected version '3.1-20140620-2+deb.sury.org~precise+4' (PPA for PHP 5.5:12.04/precise [amd64]) for 'libedit2'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [all]) for 'php-pear'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [all]) for 'php5'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-cli'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-common'
Selected version '2.15-0ubuntu10.12' (Ubuntu:12.04/precise-updates [amd64]) for 'libc6' because of 'php5-common'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-fpm'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-gd'
Selected version '3.1.2-1+deb.sury.org~precise+2' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-imagick'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-mcrypt'
Selected version '5.5.26+dfsg-1+deb.sury.org~precise+1' (PPA for PHP 5.5:12.04/precise [amd64]) for 'php5-mysql'
You might want to run 'apt-get -f install' to correct these:
libapache2-mod-php5 : Depends: php5-json
php5-cli : Depends: php5-json
Recommends: php5-readline but it is not going to be installed
php5-fpm : Depends: php5-json
pkg-php-tools : Depends: php5-json
The following NEW packages will be installed:
php5-json{a} php5-readline{a}
libt1-5{u}
The following packages will be upgraded:
php-pear php5 php5-cli php5-common php5-fpm php5-gd php5-imagick php5-mcrypt php5-mysql
9 packages upgraded, 2 newly installed, 1 to remove and 112 not upgraded.
Need to get 14.0 kB/6836 kB of archives. After unpacking 1293 kB will be used.
Do you want to continue? [Y/n/?] y
Get: 1 http://ppa.launchpad.net/ondrej/php5/ubuntu/ precise/main php5-readline amd64 5.5.26+dfsg-1+deb.sury.org~precise+1 [14.0 kB]
Fetched 14.0 kB in 0s (357 kB/s)
LANGUAGE = (unset),
LC_ALL = (unset),
(Reading database ... 38805 files and directories currently installed.)
Preparing to replace php5-mysql 5.3.10-1ubuntu3 (using .../php5-mysql_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Unpacking replacement php5-mysql ...
Preparing to replace php5-gd 5.3.10-1ubuntu3 (using .../php5-gd_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Unpacking replacement php5-gd ...
Preparing to replace php5-mcrypt 5.3.5-0ubuntu1 (using .../php5-mcrypt_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Unpacking replacement php5-mcrypt ...
Preparing to replace php5-imagick 3.1.0~rc1-1 (using .../php5-imagick_3.1.2-1+deb.sury.org~precise+2_amd64.deb) ...
Unpacking replacement php5-imagick ...
Preparing to replace php5-cli 5.3.10-1ubuntu3 (using .../php5-cli_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Unpacking replacement php5-cli ...
Preparing to replace php5-common 5.3.10-1ubuntu3 (using .../php5-common_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Unpacking replacement php5-common ...
dpkg: warning: unable to delete old directory '/etc/php5/conf.d': Directory not empty
Selecting previously unselected package php5-json.
Unpacking php5-json (from .../php5-json_1.3.6-1+deb.sury.org~precise+1_amd64.deb) ...
Processing triggers for libapache2-mod-php5 ...
Processing triggers for man-db ...
(Reading database ... 38844 files and directories currently installed.)
Removing libt1-5 ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Selecting previously unselected package php5-readline.
(Reading database ... 38833 files and directories currently installed.)
Unpacking php5-readline (from .../php5-readline_5.5.26+dfsg-1+deb.sury.org~precise+1_amd64.deb) ...
Preparing to replace php-pear 5.3.10-1ubuntu3 (using .../php-pear_5.5.26+dfsg-1+deb.sury.org~precise+1_all.deb) ...
Unpacking replacement php-pear ...
Preparing to replace php5 5.3.10-1ubuntu3 (using .../php5_5.5.26+dfsg-1+deb.sury.org~precise+1_all.deb) ...
Unpacking replacement php5 ...
Setting up php5-common (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Installing new version of config file /etc/cron.d/php5 ...
dpkg: dependency problems prevent configuration of php5-fpm:
php5-fpm depends on php5-common (= 5.3.10-1ubuntu3); however:
Version of php5-common on system is 5.5.26+dfsg-1+deb.sury.org~precise+1.
dependency problems - leaving unconfigured
No apport report written because MaxReports is reached already
Setting up php5 (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Setting up php5-mysql (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Setting up php5-gd (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Setting up php5-mcrypt (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Setting up php5-imagick (3.1.2-1+deb.sury.org~precise+2) ...
Setting up php5-json (1.3.6-1+deb.sury.org~precise+1) ...
php5_invoke: Enable module json for apache2 SAPI
Setting up php5-cli (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Replacing config file /etc/php5/cli/php.ini with new version
Setting up php5-readline (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Creating config file /etc/php5/mods-available/readline.ini with new version
php5_invoke: Enable module readline for apache2 SAPI
php5_invoke: Enable module readline for cli SAPI
Setting up php-pear (5.5.26+dfsg-1+deb.sury.org~precise+1) ...
Installing new version of config file /etc/pear/pear.conf ...
php5-fpm
A package failed to install. Trying to recover:
php5-fpm
Current status: 113 updates [-8].
Warning: Something went wrong, packages may not have been reverted
And for the command "ppa-purge ppa:ondrej/php5" gave me this :
apache2/precise apache2-bin/precise apache2-data/precise apache2-utils/precise
apache2.2-bin/precise apache2.2-common/precise dh-php5/precise
libapache2-mod-php5/precise libapache2-mod-proxy-html/precise libapr1/precise
libapr1-dev/precise libaprutil1/precise libaprutil1-dbd-sqlite3/precise
libaprutil1-dev/precise libaprutil1-ldap/precise libbsd0/precise
libedit2/precise libgd3/precise libjson-c2/precise php-pear/precise
php5/precise php5-apcu/precise php5-cli/precise php5-common/precise
php5-fpm/precise php5-gd/precise php5-imagick/precise php5-json/precise
php5-mcrypt/precise php5-mysql/precise php5-readline/precise
pkg-php-tools/precise
Disabling ondrej PPA from /etc/apt/sources.list.d/ondrej-php5-precise.list
E: Release 'precise' for 'apache2-bin' was not found
E: Release 'precise' for 'apache2-data' was not found
E: Release 'precise' for 'dh-php5' was not found
E: Release 'precise' for 'libgd3' was not found
E: Release 'precise' for 'libjson-c2' was not found
E: Release 'precise' for 'php5-apcu' was not found
E: Release 'precise' for 'php5-json' was not found
E: Release 'precise' for 'php5-readline' was not found
Unable to find an archive "precise" for the package "apache2-bin"
Unable to find an archive "precise" for the package "apache2-data"
Unable to find an archive "precise" for the package "dh-php5"
Unable to find an archive "precise" for the package "libgd3"
Unable to find an archive "precise" for the package "libjson-c2"
Unable to find an archive "precise" for the package "php5-apcu"
Unable to find an archive "precise" for the package "php5-json"
Unable to find an archive "precise" for the package "php5-readline"
The following packages will be DOWNGRADED:
apache2{b} apache2-utils apache2.2-bin libapache2-mod-php5 libapache2-mod-proxy-html libapr1 libapr1-dev
libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-dev libaprutil1-ldap libbsd0 libedit2 php-pear php5 php5-cli
php5-common php5-gd php5-imagick php5-mcrypt php5-mysql pkg-php-tools
apache2-mpm-prefork{ab} apache2.2-common libt1-5{a} php5-dev{ab}
libonig2{u} libqdbm14{u} php5-json{u} php5-readline{u}
The following partially installed packages will be configured:
php5-fpm
0 packages upgraded, 4 newly installed, 22 downgraded, 4 to remove and 112 not upgraded.
Need to get 3748 kB/11.4 MB of archives. After unpacking 4451 kB will be used.
dh-php5 : Conflicts: php5-dev (< 5.5.9+dfsg-2~) but 5.3.10-1ubuntu3.18 is to be installed.
apache2-mpm-prefork : Depends: apache2.2-common (= 2.2.22-1ubuntu1.9) but 2.2.22-1ubuntu1 is to be installed.
Depends: apache2.2-bin (= 2.2.22-1ubuntu1.9) but 2.2.22-1ubuntu1 is to be installed.
apache2 : Depends: apache2-mpm-worker (= 2.2.22-1ubuntu1) but it is not going to be installed. or
apache2-mpm-prefork (= 2.2.22-1ubuntu1) but 2.2.22-1ubuntu1.9 is to be installed. or
apache2-mpm-event (= 2.2.22-1ubuntu1) but it is not going to be installed. or
apache2-mpm-itk (= 2.2.22-1ubuntu1) but it is not going to be installed.
apache2-bin : Depends: libapr1 (>= 1.5.0) but 1.4.6-1 is to be installed.
Depends: libaprutil1 (>= 1.5.0) but 1.3.12+dfsg-3 is to be installed.
Conflicts: apache2.2-bin (< 2.3~) but 2.2.22-1ubuntu1 is to be installed.
Conflicts: apache2.2-common (< 2.3~) but 2.2.22-1ubuntu1 is to be installed.
Breaks: libapache2-mod-proxy-html (< 1:2.4.4-2~) but 3.0.1-1 is to be installed.
apache2-data : Conflicts: apache2.2-common (< 2.3~) but 2.2.22-1ubuntu1 is to be installed.
php5-dev : Depends: php5-common (>= 5.3.10-1ubuntu3.18) but 5.3.10-1ubuntu3 is to be installed.
The following actions will resolve these dependencies:
Remove the following packages:
1) apache2
2) apache2-bin
3) libapache2-mod-php5
4) libapache2-mod-proxy-html
Keep the following packages at their current version:
5) apache2-mpm-prefork [Not Installed]
6) apache2.2-common [Not Installed]
7) php5-dev [Not Installed]
Leave the following dependencies unresolved:
8) php-pear recommends php5-dev
9) phpmyadmin recommends apache2 | lighttpd | httpd
Accept this solution? [Y/n/q/?] y
apache2-utils apache2.2-bin libapr1 libapr1-dev libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-dev
libaprutil1-ldap libbsd0 libedit2 php-pear php5 php5-cli php5-common php5-gd php5-imagick php5-mcrypt php5-mysql
pkg-php-tools
libt1-5{a}
apache2{a} apache2-bin{a} libapache2-mod-php5{a} libapache2-mod-proxy-html{a} php5-json{u} php5-readline{u}
php5-fpm
The following packages are RECOMMENDED but will NOT be installed:
php5-dev
0 packages upgraded, 1 newly installed, 19 downgraded, 6 to remove and 112 not upgraded.
Need to get 158 kB/7576 kB of archives. After unpacking 10.7 MB will be freed.
Get: 1 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu/ precise/main libt1-5 amd64 5.1.2-3.4ubuntu1 [158 kB]
Fetched 158 kB in 0s (3189 kB/s)
LANGUAGE = (unset),
LC_ALL = (unset),
(Reading database ... 38843 files and directories currently installed.)
Removing php5-readline ...
php5_invoke prerm: Disable module readline for apache2 SAPI
php5_invoke prerm: Disable module readline for cli SAPI
dpkg: warning: downgrading php5-cli from 5.5.26+dfsg-1+deb.sury.org~precise+1 to 5.3.10-1ubuntu3.
(Reading database ... 38836 files and directories currently installed.)
Preparing to replace php5-cli 5.5.26+dfsg-1+deb.sury.org~precise+1 (using .../php5-cli_5.3.10-1ubuntu3_amd64.deb) ...
dpkg: warning: downgrading php5-mysql from 5.5.26+dfsg-1+deb.sury.org~precise+1 to 5.3.10-1ubuntu3.
Preparing to replace php5-mysql 5.5.26+dfsg-1+deb.sury.org~precise+1 (using .../php5-mysql_5.3.10-1ubuntu3_amd64.deb) ...
dpkg: php5-json: dependency problems, but removing anyway as you requested:
libapache2-mod-php5 depends on php5-json; however:
Package php5-json is to be removed.
pkg-php-tools depends on php5-json; however:
(Reading database ... 38827 files and directories currently installed.)
Removing php5-json ...
php5_invoke prerm: Disable module json for apache2 SAPI
dpkg: warning: downgrading php5-common from 5.5.26+dfsg-1+deb.sury.org~precise+1 to 5.3.10-1ubuntu3.
(Reading database ... 38820 files and directories currently installed.)
Preparing to replace php5-common 5.5.26+dfsg-1+deb.sury.org~precise+1 (using .../php5-common_5.3.10-1ubuntu3_amd64.deb) ...
dpkg: warning: unable to delete old directory '/var/lib/php5/modules': Directory not empty
Setting up php5-common (5.3.10-1ubuntu3) ...
php5-fpm
Setting up php5-cli (5.3.10-1ubuntu3) ...
Setting up php5-mysql (5.3.10-1ubuntu3) ...
php5-fpm
Current status: 6 broken [+5], 113 updates [+1], 64746 new [-2].
After re-adding and removing PPAs with ppa-purge. I had different output from "apt-get install php5" This time i didnt get anything from php5.5 but problem about php5-imagick :
php5 : Depends: libapache2-mod-php5 (>= 5.3.10-1ubuntu3.18) but it is not going to be installed or
libapache2-mod-php5filter (>= 5.3.10-1ubuntu3.18) but it is not going to be installed or
php5-cgi (>= 5.3.10-1ubuntu3.18) but it is not going to be installed or
php5-fpm (>= 5.3.10-1ubuntu3.18) but 5.3.10-1ubuntu3 is to be installed
php5-imagick : Depends: phpapi-20121212 but it is not installable
Than again : "apt-get -f install", and got this :
php5-imagick
0 upgraded, 0 newly installed, 1 to remove and 118 not upgraded.
2 not fully installed or removed.
After this operation, 554 kB disk space will be freed.
LANGUAGE = (unset),
LC_ALL = (unset),
(Reading database ... 37595 files and directories currently installed.)
Removing php5-imagick ...
/var/lib/dpkg/info/php5-imagick.prerm: line 13: php5dismod: command not found
dpkg: error processing php5-imagick (--remove):
subprocess installed pre-removal script returned error exit status 127
/var/lib/dpkg/info/php5-imagick.postinst: line 11: php5enmod: command not found
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 127
php5-imagick
